You would have to disassemble the lens barrel to get to the zoom sliders, and lubrication is not likely the problem anyway. The zoom mechanism uses nylon bushings sliding in a groove, and zoom problems are usually due to wearing/cracking of those bushings.
If it's still in warranty, send it in. Otherwise, the cost of repair probably exceeds the value of the lens. Sorry.
Rubber focus ring can be purchased in ebay. The rubber ring may be attached to the lens with glue. Use denature alchohol between the rubber and lens to remove the rubber ring. It can be stretched little. Once removed, clean any glue on the lens and stretch the new rubber ring and install.
turn the 'lock/friction ring' (metal band just below the black rubber focusing ring) counter clockwise whilst holding the focusing 'ring' still. The friction/lock ring is used to prevent 'lens creep' when carrying the camera with lens pointing down, or using the lens when it is pointing down. Juust turn it until it applies the level of friction you prefer for operating the lens. If you have already tried this and it won't budge it may be the bearings are shot and you will need to contact a canon service centre for repair.
The "problem" is that the lens has a zoom creep issue. If you are the original purchaser, and the lens is under 5 years old, you may want to contact Nikon repair facilites in Melville or El Segundo to have it checked out.
Some users on forums have claimed that Nikon fixed the plastics ring that contribute to the zoom creep. Apparently, using a rubber band around the zoom ring will minimize the problem.
Hope this helps,
Andrew
1) Zoom - this is by push pull - so you push the lens out to wide angle
2) To switch to manual focus - will need to be done on the camera and then you can use the front control ring to focus - 4) also you can use the button to switch to macro mode - BUT only with the Zoom at 35mm - lens fully extended
3) You have an aperture range of 2.8 - 22 this varies the amount of light allowed into the lens - 2.8 is the most light - F4 to F5.6 to F8 - each change halfs the light allowed in - so changing from F4 to F5.6 half the light
Yes, this happens even when the lens is brand new. Some other lenses have a Zoom lock to prevent it. What I did was to slip a flat rubber band around the black area just behind the zoom ring, the area where there is s white mark or line, with the band ring just touching the zoom ring. The rubber band should be fairly tight, but not too tight.
When the zoom ring revolves, the rubber band touching it gives it just enough friction to prevent it from turning. You can adjust it to give as much friction as you want.
Hope this helps.
Jay
