Question about Hitachi Hammering
Hello - I have a Hitachi Demolition Hammer PH-66A. What type of oil should I use in it? Thanks.
    Problem Solver:
  • 5 Answers
Hitachi sells a pneumatic oil for use in its air power tools. Your local Hitachi dealer, or any pneumatic dealer will sell the oil. The brand is not as important as using a few drops directly into the air fitting when starting a day of work. If used heavily, oil it again mid way through the working day.
Posted on Jan 26, 2010
6ya staff
SOURCE:
I have a PH65A Makita hammer demolition and it start working for about 10 seconds breaking and after that the hammering power slow and losses it's power hit even that motor keeps working, why?
first ordernumber 931848 lubrication necessary it has its working hours on it.
parts to change in priority
1 x 944-927 , 949457Z , 956-960 , 944-936 , 956-965 ,
999032 , 956-996 , 944-928
the important thing is that the machine is airtight at the front so as not to burn the O-rings through the air and incoming dirt friction look the orings good and if the lock bolt on the front feel not smooth replace that also and every oil seal you can find its different what should neccesary but that the tool runs with thick and dirt beaten oil . solvent clean the hard metal parts and replace if there are grooves on or cracks
Hitachi PH 65A Demo Hammer Parts
Feb 28, 2016 | Makita Hammering
How to put oil in Hitachi H65
OIL ?? I think Hitachi has always a yellow grease lubrication
hitachi grease demolition hammer Google zoeken never seen heart of oil in Hitachi demolitions. but there could be models in your Country thats new for me .
Otherwise BOSCH HILTI and the one and only brand DUSS demolition hammers and also a few brands of Chinese hammers need oil lubrication . an expensive sinc-free hydraulic oil the same as used in some pressure washers life lasting oil but for HItachi look at the link for the grease 2 tubes a enough . good luck and dont forget the piston pin to replace with a new not only the gaskets and o-rings and also the oil and dirt seals on the front where the striking pin is that must be absolutely not air leaking because all your work burns in a few months again out . you can start all-over again.
May 15, 2014 | Hitachi H65XXX 1 - 1/8 " Hex Shank...
What kind of oil can I use in my hitachi H65?
Hitachi hammers use 30wt non detergent oil. But you can use lighter oil in cold climate. If too much oil accumulates in hammer, it may just come out bit retainer or build-up inside gun. Oil enters the hammer by wick process, of wick is missing oil will enter too quickly. If your brand label is glued on, you may have a hitachi copy from china (most hitachi labels are rivited on). China hammers may use different oil.
Jul 29, 2011 | Hitachi H65XXX 1 - 1/8 " Hex Shank...
I have a demolition hammer hitachi fl-hd019, my question is what kind of oil do I have to use?
For most climates a good oil to use is air compressor oil (mineral). Sold at Lowes and many other stores. It has great lubrication properties and can take good amount of heat. In very cold climates where oil could thicken, store hammer indoors to keep warm until ready to use. Good luck
Jul 01, 2011 | Hitachi Hammering
I have a Hitachi demo hammer modle # H 65 When I frist was using it the bit had oil on it. When I got done using it I cleand it all up.When I went to use it again there wasent any oil on the bit after I...
Demo hammers do not oil/grease the bit. The grease in the tool is to lubricate and cool the parts in there doing the hammering. The bit should have grease on the end going into the hammer to make it work in the tool better and make it easier to take out when you are done. You have to put the grease on the bit yourself.
Feb 02, 2011 | Hitachi H65XXX 1 - 1/8 " Hex Shank...
Bosch demolition hammer oozing grease/oil.
Look around there for some O rings we have had this same problem with some of our Bosch hammer drills, and they usually replace a set of seals around the nose of the tool
Jul 05, 2009 | Bosch Hammering
Does the Hitachi H45MRfunction as a rotohammer for drilling?
typed in model number H45MR and this is a demolition hammer only, This tool doesn't have rotation, they do have other models that can do light demolition and also drilling
Jan 20, 2009 | Hitachi H45MR 12lb. SDS Max Chipping...
Hammering Logo
674 people viewed this question
Top Hitachi Hammering Experts
John Trevino
Pieter Vleeshouwers
Pieter Vleeshouwers
ray gallant
Are you a Hitachi Hammering Expert? Answer questions, earn points and help others
