Press and hold the Power, Ok, and Down (or Up) buttons for about 12 seconds until you see progressing LED lights (red, orange, and green lights) on the bottom followed by "GolfBuddy" message. This reboot will revert the firmware version back to its previous stable version.
Reading the manual Troubleshooting section it looks like your adsl connection is not working. Try unplugging your internet provider's equipment power supply and waiting 10 to 15 seconds. Then plug it back in.If this doesn't work contact your ISP.
Hello Hello, you name the error really is not on the list, the more like these and here is what it says to do. A greeting and let me know if you have been useful Formatter internal RAM or ROM error
Light pattern 3 LIGTHS ON, STABLEFormatter internal random-access memory (RAM) or read-only memory (ROM) error.Action
Unplug the printer and plug it back in.
Unplug the printer, remove any optional memory, and turn the printer back on.
i think that is the state of your battery,orange when charging,turns green when fully charged,make sure that is inserted properly,might need to be replaced
This is a common problem with the PS3, you should try to return it to where you got it, or make sure that the power connector you're using is the correct one, because even though you may be using one that is similar in size to the original, it may not support the voltage needed to power the system up.
This problem is caused by an imitated toner............ All you need to do is change it to the old cartridge and see if the light will not be stable. Well the solution i guess is simple............. just go to get a new original toner and it should work well. Hope this helps.
