Post a NEW question quoting the SERIAL NUMBER found on a label on the radio casing.
It normally begins with M + + + + + +
Late Four Digit Ford Radio Codes (no SELECT button)
ie. Ford 3000 Traffic, 4000RDS, 5000RDS, 6000RDS, 6006E, etc
Switch the radio on and the word CODE should appear in the display
Repeatedly press button 1 until the correct first digit of the code is displayed.
Repeatedly press button 2 until the correct second digit of the code is displayed.
Repeatedly press button 3 until the correct third digit of the code is displayed.
Repeatedly press button 4 until the correct fourth digit of the code is displayed.
Once the code has been correctly selected on the radio's display, press button 5 to enter.
If "LOCK 10" is shown on the display, please contact us for guidance. If the display shows "LOCK 13" code entry will not be possible, and the unit will need to be electronically decoded by a car radio servicing specialist.
Early Four Digit Ford Radio Codes (units with SELECT button)
ie. Ford 2005, 2006, 2015, etc
Switch the radio on and the word CODE should appear in the display.
If CODE does not appear immediately, press the SELECT button momentarily, and CODE should then appear on the display.
Once the code has been correctly selected on the radio's display, press the "SELECT" button to enter.
Three Digit Ford Radio Codes
ie. Ford 2000, 2001, 2005, 2007, etc
Switch the radio on and the word CODE followed by three dashes should appear in the display. These three dashes should be flashing.
Enter the three digit code by repeatedly pressing station presets 1-3 until each digit is correctly displayed, followed by preset 4 to accept the code. The unit should then function normally.
If, after switching the radio on, the three dashes do not flash, then 3 or more incorrect code entries have been attempted.
If a number 10 appears in the display, then ten incorrect codes have been tried and the unit will need to be decoded by a car radio servicing specialist.
Testimonial: "thank you for your help.have you got any solutions on how to get the code."
