On the back it has a reset button (you may press it with a paperclip). Check the manual for how long you have to keep pressing it restore factory defaults and what will these be exactly (usually admin/password or no password at all).
To Factory reset your router you need to locate the Reset Button at the back of the router. The Reset Button is the small hole at the back and you need a Pen or a Paperclip to press it. Press and hold the reset button for 15-30 seconds. Make sure that the router is on when you reset it.
To access the router page just open a browser then type 192.168.0.1. the username is admin and the password is blank.
Rate me if this will help you so that i can help other people.
If the SonicWALL's admin password is lost, there is no backdoor or other
mechanism to bypass the administrator login. Please note that prefs
files do not contain the admin name and password. So if you reset the
firmware and import a current prefs file, you can gain access using the
default login credentials ('admin' & 'password'). Without a current
prefs file, you must reset the firmware and configure from scratch.
For
models running SonicOS (Enhanced or Standard), you can reboot to
factory defaults. This resets all settings including the admin name,
password and LAN IP address. Import the current prefs file. The
configuration is restored and use the defaults 'admin' and 'password' to
login.
For models running Firmware 6.X, you must reset the
firmware (wipe and upload using the reset procedure). Import the current
prefs file. The configuration is restored and use the defaults 'admin'
and 'password' to login. The 'Reset to Factory Defaults' button does not
reset the admin name, password or LAN IP address for these models
