Bulldog Pushmatic  31115 P115 15 Amp Circuit Breaker Logo
Posted on Jan 25, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Breaker wont push back in - Bulldog Pushmatic 31115 P115 15 Amp Circuit Breaker
Anonymous
Level 2:
Sergeant:
  • Expert 302 Answers
  • Posted on Jan 27, 2010
Anonymous
Expert
Level 2:
Sergeant:
Answers
302
Questions
0
Helped
116134
Points
740
It is still detecting an overload in the circuit. Take the black wire off the breaker and see if it will reset. If so then you will have to trace the wires down to find the short circuit. If it doesn't reset then the breaker is bad
Why wont my Tv turn back on after the electricity went off?
Did you have your television plugged into an outlet with a surge protector? Does it do anything when trying to turn it on? Might have fried it when power came back on or when elec. went off.
Our 7788F keeps going into a ground fault condition. Need help troubleshooting. John
Ground Fault ???
Troubleshooting Ground Fault
Troubleshooting a ground fault circuit interrupt, or GFI, breaker is pretty straightforward. Troubleshooting the circuit itself can be quite time-consuming.
The GFI breaker is designed with a test button incorporated into the breaker itself.
Pushing the test button should trip the breaker.
On GFI-style breakers the neutral wire going into the house's outlets is connected to the breaker's neutral connector, the white neutral that comes out of the breaker is connected to the neutral bus in the panel, isolating the neutral bus from the neutral wire going into the house.
The test button actually shorts the neutral wire feeding the circuit to the neutral bus in the electrical panel creating a ground fault that should trip the breaker.
It is considered a ground fault because the neutral bus in the main electrical panel is actually connected to the ground bus through the panel's metal casing. What to do if the test button isn't tripping the breaker
Push the test button on the GFI breaker.
The breaker should trip.
If the breaker does not trip, then it may be that the breaker has already tripped and just looks like it's on.
The position of the switch may only move slightly from the on position towards the off position when tripped.
Push the switch on the GFI breaker all of the way toward the off position.
It may take some force to get the breaker to reset.
Turn the breaker back to the on position.
When the breaker has been reset properly you should feel some resistance when pushing the switch back on.
3 Push the test button again and the breaker should trip.
If the breaker still doesn't trip then you should test for power at the screw connections inside of the electrical panel.
Remove the screw that holds the dead front covering the breaker's connections.
Remove the dead front cover.
Test for power with your voltmeter set on AC volts on the highest scale.
For a single pole GFI breaker, touch the black lead from the tester to the silver screw on the GFI breaker and touch the red lead from the tester to the brass screw on the GFI breaker.
You should see 110 volts on the tester. If voltage is seen but the test button won't trip the breaker, then the breaker is bad and should be replaced.
5
Test for power on a two pole breaker by touching the red voltmeter lead to one of screws with a black or red wire connected to it.
Touch the black lead to the other screw with a black or red wire connected to it.
You should read 220 volts or close to it on your voltmeter.
If you read voltage and the test button won't trip, the breaker is bad and needs to be replaced.
What to do if the breaker won't reset and keeps tripping when turned on
6
Unplug everything that is plugged into any of the outlets on the circuit in question.
Try resetting the breaker again by pushing the switch all the way to the off position and then turning it back to the on position.
If it won't reset and trips when the breaker's switch hits the on position, it could be a bad breaker or a problem in the circuit itself.
7
Use your straight-tipped screwdriver to loosen the brass connection screw or screws on the GFI breaker.
Pull the black hot wire, or wires, out of the breaker's connectors.
Loosen the silver screw the white wire is connected to and remove it from the GFI breaker.
8
Push the switch all the way to the off position.
Turn the switch back to the on position.
If the breaker still won't reset, then the problem is the breaker itself and it should be replaced with a new one of the same size, brand and model.
If the breaker resets normally and the test button trips the breaker when pushed, the problem is in the circuit itself and an electrician should be called to find your ground fault.
9
Reconnect the black wire, or wires, to the brass screws on the GFI breaker.
Reconnect the white wire to the silver screw on the GFI breaker.
10
Replace the dead front cover into the breaker panel.
Install the screw or screws that hold the dead front in place.
http://www.hilo-electric.com/blank?pageid=63
While playing my unit we had a brief power outage. When the power supply returned the " PROTECT PUSH POWER " message comes on. Is there a button that I can push to reset my unit-LBT-X50 .
Your sound system may have a circuit breaker.
Check the rear of the sound system for a circuit breaker that has popped out, Then push it back in.
It may be labelled.
  • circuit breaker
  • protect push power
Otherwise unplug your unit from the wall and wait 5min before you plug it back in, then press the power button on the front of your system and your remote control.
I hope this helps
MobileJB
I turned of my main 150 amp circuit breaker at my home and now it wont come back on. it just wont switch all the way on just half way how do i fix this?
My electrician buddy says never turn off the main on the weekend.
Main breakers are subject to heat for a long time. Heat shortens the life of all electrical devices.
Click main all the way to one side, and then push back
If it doesn't engage, then the breaker is probably bad
How do I turn on the circuit breaker on my goodman ac? The smarter Tec flipped the circuit breaker. Do I turn it or push it?
If it is the breaker box in your house, then just push it to the side so it is lined up with the other breakers in the box. Actually any breaker will be like that. If it is the disconnect outside then it pulls out and you flip it over and put it back in.
My fuse on my washing machine flipped off and wont flip back on. when I push it in, it doesnt click. Before this happened the fuse my fridege is on blew and I pused this one on accident before I put the...
If you by "fuse" mean automatic breaker, that protects the line to your washing machine etc. it may not return to its "on" position when the trouble that caused it to drop is still present.
If you disconnect (unplug) your washing machine and try to reset the breaker it may click back. If it doesn't and you have nothing else connected to this feeder, the breaker may be bad and needs to be replaced. The line to the washing machine also may be bad.
Jul 10, 2010 • Hammering
I pushed the reset button on my power cord which my refridgerator is plugged in to. I immediately turned it back on. I now no longer hear it's fan. Is there a reset button I need to push on the refridge?
There is no reset button on the Refrigerator, however you need to make sure the power cord is supplying power from where it is plugged, also check the breaker in the eletrical panel box to make sure the breaker has not been tripped, if so you will have to push the breaker to the off position and back to the on position.
20 AMP Cutler Hammer CH GFI wont fit in the breaker box
It will fit, the extra bump out on the back makes it a bit harder to hook the back locking tab before you push it on the bussing. Also, make sure no wires are in the way obstructing the bump out since it hangs out further than the standard breakers. The most common problem is the bump out making it hard to hook the locking tab onto the outer rail. Make sure the breaker is in the off position, then try holding it more flat as you insert it keeping it close to the bussing. This will help keep the extra bump out from obstructing the locking tab from hooking the back rail. Once it's hooked on the back rail you can push it on the bussing like normal.
I turned it off for about six months, now it will not reset. There are no loads applied.
you must push it kind of hard to get it to reset. first kill the 100 anp or 200 amp breaker. that is what most of sizes used now days. it will be the big wide breaker. now pull the wire our of your eaton breaker. if it has 2 wires pull them both. it has just one pull it. move it back where you wont touch it or it wont touch anything else. now reset it again. it it resets you have a bad short down the line. let me know and i will help you run it down. good luck and good day. sawdust46
Thanks, however I have a new issue
thats possiable.but most common is the breaker trips[house breaker]push both 50 amp stove breaker all the way to off.push ,off direction to make sure resetts,then to on.if still no work you can do visiual inspection,but other wise need volt meter
Top Bulldog Electrical Supplies Experts
Sean Wright
Sean Wright
john h
Are you a Bulldog Electrical Supply Expert? Answer questions, earn points and help others
