Question about Mitsubishi WD-65733 65" HDTV
Mitsubishi wd65733 lamp /housing install, do i just 'push' it in? The connectors don't seam to be clipping together
    New Friend:
Wht is the purpose of the ballast?
Posted on Nov 09, 2010
  • Anonymous Nov 09, 2010
    i get a code 39, does the ballast make the tv overheat if not working right?
    wht is the purpose of the ballast? if not working right does it make tv overheat?
  • 59 Answers
You should just push it in carefully thats all it takes
Posted on Jan 25, 2010
Anonymous
SOURCE:
How to remove the DMD shield on Mitsubishi wd65733
Don't know why you are removing it; if you are replacing the bulb I suggest you use the bulb replacement that is complete with new housing already.
Nov 28, 2014 | Mitsubishi WD65733
BULB IS BLOWN ON THE MITSUBISHI WD65733
your model uses the Mitsubishi 915061010 Lamp assembly with housing which is available from www.tvrepairworld.com under the Mitsubishi DLP Lamp category. The lamp comes with installation instructions and is a simple plug in , It includes the housing so you dont need to remove the old bulb from your housing to reuse since the new lamp already has the housing with it.
Aug 22, 2011 | Mitsubishi WD-65733 65" HDTV
WD65733 Mitsubishi projection HDTV worked fine last night. This morning when I turn it on I can hear sound but no picture. After a minute it turns itself off. What is the problem?
Most likely just needs a new lamp.
the lamp is easy to replace , google for the lamp to buy one online.
a few screws hold the lamp door and lamp in place.
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Dec 17, 2010 | Mitsubishi Televison & Video
How do I fix the light in the heater control?
The heater control will have to be removed and possibly disassembled to get at the bulb.
1995-98 Models
  1. Disconnect the negative battery cable.
  2. Remove the radio/HVAC controller cover by depressing the center pins inward to release the push pin fasteners. Be careful not to push the center pins all the way through the fasteners.
  3. Remove the push pin fasteners and pull the radio/HVAC controller cover rearward.
  4. If equipped, disengage the traction control/fog lamps/rear defogger electrical connector.
  5. Remove the radio. Refer to the Radio removal and installation procedure, later in this section.
  6. Disengage the electrical connectors behind the controller face. Remove the wiring harness clip from the module boss.
  7. Disengage the temperature and mode cables from the controller assembly by squeezing the lock tabs together while pulling the cable housing straight up. Pull the cables straight up to disengage them from the control lever pins.
  8. Remove the HVAC control panel screws, then carefully pull the panel forward and remove it from the vehicle. To install:
  9. Position the HVAC control panel to the dashboard and install the retaining screws. Tighten the retaining screws to 22 inch lbs. (2.5 Nm).
  10. Install the white temperature and black mode cables over the pins.
  11. Install the cable housings into the clip grooves, then push down to lock them into position.
  12. Reattach the electrical connectors to the back of the control panel face. Install the wiring harness clip to the module boss. Be sure that the wiring harness does not bind with control lever movement.
  13. Install the radio.
  14. If equipped, reattach the traction control/fog lamps/rear defogger electrical connectors.
  15. Install the radio/HVAC controller cover by pushing in at the clip locations.
  16. Install and lock the push pin fasteners.
  17. Connect the negative battery cable.
Oct 26, 2010 | 1998 Saturn SL
Sound and no picture and changed lamp
I have this same problem. I found that when pushing the lamp in, it actually pushed the connector out the back of the housing. I will have to completely take apart the TV to repair connector.
Feb 26, 2010 | Mitsubishi WD-62525 62" Rear Projection...
I need to see the lamp housing unit with connectors for the mitshubishi wd-52825. i replaced the lamp and have the same problem reported by most (no picture, then lamp light turns red). it appears as...
yes, if you look at the back of the lamp unit you will see a plug, if you pushed a little too hard when trying to plug it back in you may have pushed the corresponding plug out. Take the back off and look and find the case that the lamp sets in and see if the connector has been pushed out.
Sep 11, 2009 | Mitsubishi WD-52825 52" Rear Projection...
HOW TO REPLACE HEADLIGHTS ON 2000 CHRYSLER LHS
ATTN: NIKKICARROLL
here is how to replace the bulb in your vehicle
  1. Release the hood latch and open the hood.
  2. Remove the radiator closure panel sight shield as necessary to gain access to the headlamp.
  3. Remove the screws holding the headlamp module halves together.
  4. Separate the module halves.
  5. Disengage the wiring from the headlamp bulb.
  6. Remove the retaining ring from the back of the headlamp bulb.
  7. Pull the bulb from the lamp.
To install:
  1. Push the bulb into the lamp.
  2. Install the retaining ring to hold the bulb in the lamp.
  3. Engage the wire connector to the back of the headlamp bulb.
  4. Place the module into position on the vehicle.
  5. Install the screws to hold the module to the vehicle.
  6. Install the radiator closure panel sight shield.
  7. Check the headlamp alignment and operation.
88176gb1.gif Exploded view of the fog lamp with the bulb removed
Click to Enlarge
  2. Remove the radiator closure panel sight shield as needed to gain access to the headlamps.
  4. Separate the halves.
  5. Remove the fog lamp wire connector cover.
  6. Disconnect the wires from the fog lamp bulb.
  7. Disengage the retainer clip holding the bulb to the fog lamp.
  8. Remove the bulb from the fog lamp.
To install:
  1. Place the bulb into position in the fog lamp.
  2. Engage the retainer clip to hold the bulb to the fog lamp assembly.
  3. Attach the wire connectors to the fog lamp bulb.
  4. Install the fog lamp wires connector cover.
  5. Place the module halves together.
  6. Install the screws to hold the headlamp module halves together.
  7. Install the radiator closure panel sight shield.
  8. Verify the fog lamp operation and alignment
ATTN: WDSNEED1
Removal & Installation 88176g87.gif Remove the screws retaining the headlamp module to the mount adapter
Click to Enlarge
  2. Remove the radiator closure panel sight shield as necessary to gain access to the headlamp fasteners.
  3. Remove the screws holding the headlamp module to the mount adapter.
  4. Separate the headlamp module from the mount adapter.
  5. Disengage the wiring from the headlamp and foglamp.
  6. Remove the headlamp from the vehicle.
To install:
  1. Attach the wires to the headlamp and foglamp assembly.
  2. Place the headlamp module into position on the mount adapter.
  3. Install the screws to hold the headlamp module to the mount adapter.
  4. Install the radiator closure panel sight shield.
  5. Check the headlamp alignment and operation.
Jul 28, 2008 | 1994 Chrysler New Yorker
Red Lamp Light
The problem lies in the heat sensor that sits just inside the lamp housing area inside your set. Apparently the technician fix is to clip the faulty connector Mitsubishi used when assembling the set and replace it with a soldered connection instead. My fix is simpler and does not require solder. My TV is a 57831 model so it may differ from others but not much if so. Here is what I did.
1.) Remove the two screws holding the lamp door to the set in the back lower right corner of your set.
2.) Follow the set instruction for removing the lamp assembly. it should be unplugged for an hour prior to doing this.
3.) Once assembly is removed, grab your flashlight (if necessary) and look inside the housing. You should see a white rectangular shaped piece attached to the outer frame edge of the opening. Looking straight on, it is located in the upper left corner of the square opening and is held in place by one small phillips head screw. This screw is inserted and installed from the opposite direction and will require the short screwdriver to remove. Carefully remove it and don't drop inside the set!
4.) To make room to move around and do what you'll need to do, you will also need to partially remove the back cover of the set. Mine was limited to just the lower half and was held in place by nearly 20 screws. You don't need to remove all of them but do need to be able to open up the rear enough to access the connecter that sits on top of the upper left edge of the lamp housing. If you follow the two yellow wires from the white sensor, they track back to a small black connector with two black wires on the other side of it.
5.) At this point, you have removed the screw to the sensor. Now you will need to pull the connector wires free from the routing clip on top to free up space for the wire to move freely. Once these two black wires are pulled from the clip, pull the white sensor down from it's position to free it from it's housing and allow the yellow wires to be pulled from the left side of the housing out. If done right, the sensor is free now and can be pulled carefully by the connector at top and out the back of the set.
6.) Squeeze the clip connection where necessary and pull the clip assembly apart. The sensor is now free of the TV entirely and you can work with it separately.
7.) Grab a nail file and work the connector pins a little to roughen the contact points a bit. This is similar to cleaning the contact posts on your car battery.
8.) Push the male end of the clip firmly into the female end until it clicks and then push a little harder to be sure good contact is made.
9.) Do the reverse as done above to put it all back together again and power up!
10.) The message should now be gone.
Nov 10, 2007 | Mitsubishi WD-52725 52". Rear Projection...
525725 go's off 30 min. intervals.
Check the air filters and if they are clean and there is plenty of room around the TV for venting, Try:
Nov 09, 2007 | Mitsubishi WD-52725 52". Rear Projection...
Lamp switches off
The problem could lie in the heat sensor that sits just inside the lamp housing area inside your set. Apparently the technician fix is to clip the faulty connector Mitsubishi used when assembling the set and replace it with a soldered connection instead. My fix is simpler and does not require solder. My TV is a 57831 model so it may differ from others but not much if so. Here is what I did.
Oct 01, 2007 | Mitsubishi WD-52725 52". Rear Projection...
Mitsubishi WD-65733 65" HDTV Logo
326 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Ekse
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
