Is there any computer connected to the router with the cable ?
If not then you will need to connect the computer to the router.
Check the Ip address and default gateway. default gateway will be the current Ip address of your router.
Once you open the router set up page with the current IP address , you will be able to change the IP address of the router
Click Here for more information about the router and network
SOURCE: change ip address of recently installed router
The 192.168.0.1 is the device IP.
Your trying to change the "Default Gateway" mine is set to 192.168.1.1
Let me explain (:
1.Go to start>run>type "cmd" without quotes and press enter.
The black screen should appar, in that screen type "ipconfig/all" without quotes.
And press enter.
This is what mine looks like:
I took out some things to my security, but basically this is what some of these things represent.
For you, your IP it shows would be something like:
192.168.1.101
Each device hooked up to your network gets its own IP it will start at 192.168.1.101 for the first device, then 192.168.1.102 then the next device gets 192.168.1.103,etc...
Your default gateway, 192.168.1.1 is where it starts, to change this go to:
Here is a example of what mine looks like:
I hope this educated you, and helped you fix your problem for more help visit www.pc-fix.us or just reply here.
Thanks,
Cam
SOURCE: belkin router f5d8230-4 ip address change
I am a belkin partner I can help. You can call me
661-588-4401 I can help you out
SOURCE: i changed my dlink dir-300 router's ip address
Yes, resetting it will revert it back to factory settings (and therefore original IP address). Sometimes it is best to start over when something like this happens. ;)
Remember though, if you are configuring your router with a wireless connection you need to disconnect/reconnect to you wireless network (because you just changed it's address).
NOTE: If the IP address of the router has been changed, type the router's IP address in the "Address" bar instead.
The router's IP address can be changed by:
If you forgot the router's IP address you can:
Step 3:
A new window will prompt for a User name and Password. Leave the User name space blank, type in your router's password ("admin" is the default password), then click OK.
NOTE: If the password of the router has been changed, type the router's new password in the Password field instead.
The router's password can be changed by:
NOTE: If the IP address of the router has been changed, type the router's IP address in the Address bar instead.
1. Running the router's setup CD.
2. Changing it on the router's web-based setup page.
1. Check the router's IP address. For instructions, click here.
2. Press the Reset button at the back of the router for 30 seconds.
NOTE: This procedure will reset your router to factory
defaults. Any settings on the router will be erased. The router's IP
address will be "192.168.1.1" and the password will be "admin".
Step 3:
A new window will prompt for a User name and Password. Leave the User name field blank then enter your router's password ("admin" is the default password), then click OK.
If you forgot the router's password you need to reset the router. For instructions, click here.
