First thing to check is the water connection. If your water is connected using a saddle valve, it has probably developed a blockage. The saddle valve makes a pin-sized hole in the water pipe and it is prone to accumulating lime and water scale which slows and even blocks the water supply.
If you find that is the problem, replace the saddle valve with a 1/4" tee fitting and the problem should go away permanently.
