SOURCE: monitor goes to sleep and won't wake up
Yeah, im not sure about how to fix the problem with it shutting down like that, but one option is to go under your control panel and taking off the sleep function, or putting it on a 4 hour timer so that doesnt go into sleep mode anymore. However, the problem is not your monitor but your computer. Id just take the sleep mode off, there is no need to have it on.
SOURCE: power saving mode knocks the computer out, have to restart
I have an LG Flatron 19" black w1952TQ that I bought on 2 Apr 2008; when it goes into sleep mode, will not recover. Did the online troubleshooting, reseting things, unplugging/replugging all cables, nothing works except restarting the computer, and that only works until it sleeps... Read more
SOURCE: Analog power save mode
i had the same problem with the same screen as you.
i connected the usual blue plug on my pc, and i got the same message as you did.
i finally realised that i connected it on the on-board graphics card(VGA?)
i added a new plug(adaptor) and then connected it on my graphics card.
everything works now!
It's just tha we are all used to the shape/colour of the port on our PCs
SOURCE: monitor goes to sleep and never wakes up
if you are on the desktop, right click and choose nvdia control panel and choose the nview display mode to use. select only use one display(single) maybe your input signal is in the wrong selection.just try it maybe it will help
SOURCE: hp vs17e monitor says it's in sleep mode then goes blank
If you are running Windows Vista,do the following,
If you are running windows Xp
if this doesn't fix your problem,please let me know
Please rate this a fixya
