It can be caused due to any driver clash or antivirus . With some computers if you press and hold a key as the computer is
booting you will get a stuck key message as the computer is booting. If
this occurs instead of pressing and holding the "F8 key" tap the "F8
key" continuously until you get the startup menu.
Windows Advanced Options Menu
Please select an option:Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice.
As
can be seen from the above example, you should be able to highlight and
press enter to load the last known good configuration. Once completed
the computer should restart and attempt to load into Windows.
