HD500 is yet to be hacked, but you may try the methods below.
1. Open the disc tray
2. Press 2, 1, 6, 8
3. Use ENTER to select the region (9 = codefree)
4. Close the disc tray
2. Press SETUP
3. Press 1, 3, 6, 9
4. (Press LEFT, LEFT, LEFT, RIGHT)
5. Select region with UP/DOWN (0 = codefree)
6. Press ENTER
7. Press SETUP
8. Close the disc tray
1. Turn on the player (without a disc inserted)
2. Press SETUP
3. Press 1, 3, 6, 9
5. A new menu entry appears ("Version")
6. Select it
7. Go to "Region" and select 0 for multi-region
8. Press SETUP
2. Press SETUP
3. Press VOL+, VOL-, VOL+, VOL-
4. Select region (255 = codefree)
5. (Press ENTER)
6. Close tray
1. Open tray
2. Press REPEAT
3. Enter 9, 5, 2
4. Press REPEAT
5. Enter the region you want (0 = multi-region)
6. Press REPEAT
7. Power off
1. Open tray
2. Press SETUP
3. Enter 9, 3, 0, 1, 0
4. Press STEP, SHUFFLE, NEXT
5. Close tray
6. Power off and on again
1. Open tray
2. Press SETUP
3. Enter 9, 2, 1, 0
4. Select region (0 = multi-region)
5. Press SETUP
1. Open the tray
2. Press SETUP
3. Press RIGHT, RIGHT, RIGHT
4. Enter 1, 3, 7, 9
5. Enter 0 for multi-region
6. Press SETUP
7. Close the tray
8. Turn the player off
1. Open tray
2. Press VOL+, LANGUAGE
3. Enter 2, 3, 7, 9, 2, 2, 2
4. Select region using UP/DOWN (0 = multi-region)
5. Press ENTER
2. Press CLEAR
3. Press 2, 5, 8, 0
4. "Testmode" is displayed
5. Press UP, UP
6. "1402" is displayed
7. Press 0, 0, ENTER
8. "1400" is displayed
9. Press UP, UP
10. "1235" is displayed
11. Press 3, 3, ENTER
12. Display changes to "1233"
13. Press RETURN, RETURN
14. Close the disc tray
15. Turn the player off
1. Open tray
2. Press CLEAR
3. Enter 2, 5, 8, 0
4. Press CLEAR
5. Go down to "1402"
6. Press 0, 0, ENTER
7. Go down to "1333"
8. Press 7, 3, ENTER
9. Go down to "1235"
10. Press 7, 3, ENTER
11. Press RETURN, RETURN
12. Power off
1. Press PLAY ("NO DSC" will be displayed)
2. Press GO TO, PREV, NEXT, DISPLAY
3. Press 3, 3, 0, 8
4. Press ENTER
2. Press 8, 1, 3, 2, 8
3. Select region using ENTER (9 = codefree)
1. Insert a DVD
2. Press STOP, CLEAR
3. Enter 2, 5, 8, 0
4. Press CLEAR
5. Select the region (0 = multi-region)
6. Press RETURN
1. Open the tray
2. Press 0, 5, 2, 0
3. Pres UP, DOWN, LEFT, RIGHT
4. Close the tray
2. Press 3, 8, 3, 8
3. Select region (9 = codefree)
4. Close tray
2. Press and hold RETURN on the remote
3. Press DISPLAY
4. A line with letters and digits should appear
5. Press DISPLAY several times until the last digit is 0
6. Release RETURN
7. Press ANLGE
1. Open tray
2. Press and hold RETURN and VOL+
3. Release the keys
4. Press 2, 3, 7, 9, 2, 2, 2
5. Select region (0 = multi-region)
6. Press ENTER
These are the instructions for a TEAC DV-H550, perhaps they will work with your model as well:
If the above settings are incorrect, correct the setting as follows:
This is also a possible solution for the H500, but unconfirmed:
I hope that helps.
Hi
Thanks for using FixYa. To make it multiregional please follow these step by
step instructions using
your remote control:
1. Switch power on
2.
Open the DVD tray (leave it open with no DVD in it)
3.
Press "stop"
4.
Press "734466"
5.
Use cursor to scroll up or down until it says "Region 0"
6.
Press "OK/Enter"
7.
Switch power off
8.
Switch power on
It show now
play all region DVD’s.
Please do accept the solution if the issue is resolved or else revert for
further assistance.
Thanks
Rylee
Tried it 3 times and nothing happened. Nothing changed on the display changed at all at any stage during the procedure. My dvd player is still single region. Please help me - i have several foreign dvd's i can't play! Thanks.
I tried the first set of instructions - this did not work but it did access some kind of hidden features: On the display on the machine, it read "CFG INIT" and on the TV it displayed "EEPROM ERASE DONE... REBOOT" but nothing has changed.
The second instruction is not possible on this machine as there is no OK button and no ENTER button.
