I have the LTV-32 in Westinghouse tv. It is about 3 years old, lately the color goes all pink and blue and the dark colors all look black after being on for a few minutes and heating up. Going to take it in for repair but would really like to have an idea what is wrong before I take it in.
Ur Tuner signal board is dying,must replaced.
Testimonial: "thanks for the help."
Naw, simple fix!!! Listen to LarryK420 on this forum:
http://www.avsforum.com/avs-vb/showthread.php?p=18039617#post18039617
and see my posts at the end. CLEAN YOUR LCD CONTROLLER RIBBON CABLES. It only took a single average size Phillips head screwdriver and an eraser. Remember where the different screws go, fine thread into metal, coarse thread into plastic, and make sure all the cables you disconnect are reconnected correctly and securely. Power it up and make sure all is well, before you put it all backtogether. I thought great, I still have a picture, put all the screwsback in, then no sound. The clip came off with the speaker cable, and I put it on backwards. Luckily no permanent consequences, but I had to reopen the TV and flip it, then it was loose, so I bent it back a bit so it was more perpendicular to the board, and it all stayed snug. I can't believe it seems not to be some overheating or failing component, costing lots of money, totally free.
