There is a filter at the rear of the washer.
Remove lower rear panel.
Remove large black hose from bottom of drum.
Remove and clean filter in inside hose.
Remove hose onto pump and check for blockage oe obstruction here as well.
Please rate my solution.
Thankyou.
need more instruction on how to remove large black hose at bottom of drum :-(
You need a screwderiver to remove the large clip holding the hose to the bottom of the drum, although on some models there was a large plastic clip fitted, if this is the case, then you need to prize the clip open to remove it.
