Hi, My Sony Wega TV turns on normally with the green standby/power light flashing, but after about 40 seconds its shuts off without the the standby/power light turning red as it usually does when you turn it off. The standby/power light blinks several times then the tv(picture) comes back on for another 40 seconds, then the process repeats. Please note that the lamp light NEVER turns on, so per the manual, it is not a lamp issue, or is it. Please advise. -Felix
SOURCE: Sony Wega KP-FW46 - Standby Flashing 10 Times
Remotes can be ordered from various websites, I would check ebay, sony, those type of websites. The standby light flashing means your bulb on the TV needs to be replaced.
Good luck.
SOURCE: Sony grand wega started turning on and off continuously
The usual problem is that the lamp needs to be replaced. However, there is no guaranty that lamp replacement will correct the problem.
To figure out how to replace the lamp please visit
The frequently asked questions for Grand WEGA KF50XBR800 50 in. Rear Projection
http://www.agoraquest.com/viewforum.php?forum=70
SOURCE: Sony Grand WEGA KDF-60XS955
I had the same problem and it costs 200.00 dollors for the lamp that bad
SOURCE: power light flashed red 4 times then repeats no pic,new bulb/fan!
Check the fan that cools the bulb. It is directly behing the bulb. It should turn on when the power comes on. It apparently has a safety to protect your tv(and home). mine is in the process of going out. looking for online solutions as we speak.
