Question about Westinghouse TX-47F430S 47 in. LCD TV
No picture from dvd when using hdmi cable
No picture from blu-ray dvd player when using hdmi cable to Westinghouse TX-47F430S TV. Works fine on other TV.
    New Friend:
  • 4 Answers
Make sure tv is on correct source for that hdmi input.
Posted on Jan 27, 2010
6ya staff
SOURCE:
Why won't my westinghouse tv model tx 47f430s play bluray, but it will play regular DVD's just fine though?
This fault is not a user repairable one, especially to blu-ray players. Contact the authorized service center for Westinghouse.
Gopakumar Gopalan Google
May 16, 2014 | Westinghouse Televison & Video
Onkyo tx-nr509 no picture with blue ray dvd player
Hello, I am sorry about your issue. Have you tried the other HDMI ports on the receiver. Please check the cable from the receiver to the TV. Thank you, Onkyo USA
Mar 07, 2017 | Onkyo TX-NR509
How to hook up a panosonic 50" Flat screen plasma
Try connecting TV to DVD with a scart lead or a hdmi cable now hdmi v cables are the next best thing from a scart lead
Dec 21, 2011 | Televison & Video
No Sound comings from bp 1500
hi i have had this you sometimes get a delay on the sound when you boot up i just changed my hdmi lead and it rectified it try using a 1.3 instead of 1.2 hdmi lead.
Mar 21, 2009 | Samsung BD-P1500 Blu-Ray Player
Is using the HDMI at the receiverr better
Unless you have a Blu-ray DVD player you should be fine using HDMI into the receiver first.
Feb 26, 2009 | Onkyo TX-SR705 Receiver
Compatibility with Samsung LCD Display
It sounds like the HDMI port on the back of your Marantz is damaged. if you know for sure that the HDMI port works on another tv still you might just use component connection because the visible difference between component and HDMI is not very recognizable.
Jan 13, 2009 | Marantz DV4001 DVD Player
HDMI connection with Panasonic DMP-BD35K Blu-Ray Disc Player
Try hooking the Panasonic up straight to the tv without going through the receiver. If it displays a picture its obviously not the blu-ray player. May also be a problem with the HDMI cable itself. Hope this helps.
Jan 04, 2009 | Onkyo TX-SR506 Receiver
Open Questions:
My Westy 47 TV has a very strange power-up problem! First, I found that the power supply was bad, I couldn't repair it, so I bought a replacement from ShopJimmy. The replacement seems to be working fine, and sometimes the TV works fine. The little green LED near the bottom edge of the controller board lights up when you connect the AC power, as it should. There is also a small green LED near the upper edge of the controller board that apparently lights only up when the controller is working properly. I've replaced the 470 mFd, 16 V. 'Lytic on the controller board, as everyone says to do. I still observed about 0.8 Vp-p of digital signals on the 5 Volt buss with the replacement capacitor these signals looked kind of like a 300 kHz clock and some other misc. digital stuff, so I added a couple of 0.1 mFd disc ceramics directly across it on the bottom side of the board. That reduced these signals to about 0.4 Vp-p, but the TV still won't turn on. The orange pilot light on the front is lit, but neither the buttons nor the remote will turn it on. The only way I can get the TV to turn on is to do the following: 1. disconnect the two power cables going to the two lamp inverter boards; 2. plug the AC power cable in. The 2nd green LED on the upper portion of the controller board now lights up when AC power is applied. 3. plug in both power cables to the two inverter boards while the power is on. The TV now works fine - all of the lamps light up, good picture, blue LED on the front panel, the remote works, etc. However, if I turn the TV off, and try to turn it back on, the small green LED on the upper controller board goes off, and the set won't come on! I've tried holding the on/off button down for over 10 seconds I read that this might re-boot the controller to no avail. The only way to get it back on is to go thru the 3 above steps again. I've read that there appear to be several versions of the firmware, and I wonder if this might be a firmware problem. If so, how/where can I get the proper firmware to install? Any suggestions? HELP! Please If someone would like to call me, please do at ************. Thanks, Gary W3DTN
Dec 28, 2015 | Westinghouse TX-47F430S 47 in. LCD TV
See all Westinghouse TX-47F430S 47 in. LCD TV Questions
Westinghouse TX-47F430S 47 in. LCD TV Logo
269 people viewed this question
Top Westinghouse Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
