NAD T760 I PLUG SIGNAL THRU CD INPUT, TAPE OR VIDEO AND ALL I GET IS A VERY LOW OUTPUT THRU SPEAKERS EVEN MAX VOLUME, BUT IF PLUG THRU DIGITAL OR 5.1 INPUT AND RADIO, IT SOUNDS NORMAL
Check and increase the volume level of the CD/TAPE/Video player. Also check whether the input cables are properly inserted.
Revert back for more assistance.
Hi
Thanks for using FixYa. To reset the
speaker unplug the system for more than 5 minutes and after that test the
speaker using another device. You can plug one end of a RCA female to Mini-plug
male adaptor into the headphone output jack of devices like a CD player or MP3
player. Now plug the other into either ‘line in’ RCA jacks on the sub to
determine if the problem is with the speaker or the soundcard drivers.
If still the issue is not
resolved, then you’ll need to perform the Direct CD Test for speaker to check whether
the problem is a simple cable or level-setting. Use a different set of RCA
connector cables and then connect the analog audio out from a CD player or DVD
player directly into the speaker's LINE IN connections. Then, turn the volume level
on the speaker down to the lowest. While playing a CD, raise the volume level
on the speaker and now you should hear the bass portion from the source
material. If still the issue persists, then the issue may be a blown woofer or
sub amplifier. If the speaker functions correctly, then the issue may be with a
cable, the receiver and/or a level setting.
Please do accept the solution if the issue is resolved or
else revert for further assistance.
Thanks
Rylee
Make sure the "MONITOR" mode is not selected or turned "ON".
Just a guess, Good luck !
I ALREADY TRIED BUT REMAINS THE SAME
THINKING IT MIGHT HAVE SOME SETTINGS PREVIOUSLY DONE AND SINCE I DONT HAVE THE REMOTE CONTROL
TRIED SOME BUT THE THING IS LIKE YOU SAID IT MIGHT HAVE SOMETHING TO DO WITH THE SOUNDCARD DRIVERS, BUT I DONT HAVE SCHEMATIC NEITHER THE REMOTE TO ADJUST THE OSD SETTINGS.
IF THE PROBLEM IS IN SOUNDCARD DRIVERS WHAT DO I HAVE TO DO,FM SOUND OK AND USING COAXIAL DIGITAL INPUTS OR 5.1 INPUT ARE THE SAME OK LEVELS, IF DRIVERS BAD WOULDNT IT BE THE SAME FOR ALL OR EACH INPUT HAVE DIFFERENT DRIVERS.
