www.elab.ph/forum/index.php?topic=41147.0;wap
sharp 21v-fk200m flat screen crt. Pages: (1/4) > >>. bobet20: pahelp po mga master,may problema ako malaki,,,sunog po resistor sa power supply r704,,syaka
Feb 17, 2015 - Question about Sharp Standard (CRT) Televisions .... What is the valueof resistor R704 in SHARP TV model 21V-FK200M circuit diagram.
Sharp value 2 watt resistor Standard (CRT) Televisions ...
www.fixya.com > ... > value 2 watt resistor > Standard (CRT) Televisions
value of r707 sharp model #27c241 R707 is 27 ohm 1/2 watt carbon resistor,if you ... What is the value of resistor R704 in SHARP TV model 21V-FK200M circuit ..
One color predominant scree; is the fault said. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Reason for this fault and the repair work has been described in detail by one among the post.
Reason/s for one color predominant screen to CRT TVs are described in detail by one among the post there.
If this were a degaussing issue then I would expect to see red, green, and blue but with distortion. That isn't what you're reporting. As has been suggested already, you likely have a component area (like vertical or horizontal sweep) that is malfunctioning because of a failure. The failure could be system voltage oriented or a component board or combination of both. Here is the bottom line, how much are you willing to spend to fix an older TV? If you aren't willing to spend a few hundred dollars then consider why a repairman would want to work for less? By the time a technician puts the set on his bench, opens it, and does preliminary system check you've got an hour invested. If a system power voltage failure caused other components to fail then the problem along with cost to repair quickly escalates.
There should be a default code, that overrides the set code, and using it you can reset it by an other code. Refer its user manual to get this override code. Electro helpGopakumar Gopalan Google
Sharp, Fisher & Sanyo will have same configuration to circuit. So, the service menu entry method to these sets will also be the same. If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/
This could be several things, but most likely a burned loose resistor or bad solder joint.
All of which causes an inoperative power supply with the result of having a "dead" set.
It would have to be checked out to find the problem.
Stargazer
