Toshiba e-Studio163 Copier Logo
Posted on Jan 28, 2010
SP MODE AND INSTALLATION PROCEDURE FOR TOSHIBA DP 1660.
Anonymous
Level 1:
New Friend:
  • Contributor 8 Answers
  • Posted on Jan 28, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
8
Questions
0
Helped
9098
Points
21
Installation Procedure:
01.Open the machine and take out all tape
02. Open the front cover and right hand side cover + blue lock press and open the black part
03. front side two scrow (big) open
04. Out of PC Unit ( drum and developer Unit)
05. done you Two part the ( drum and developer Unit)
06. developer keep on developer
07. total Items set on the machine
08. main switch on
SP mode
01. 0+5 press and main twitch same time for AJ MODE
02. 0+5 press and main twitch same time for ADMODE
What is Canon Support Code 1660?
It normally stops if you don't install the ink cartridges correctly. When the failure strick on your printer, it will not allow you to continue with the printing assembly. This error can even make the printing process quiet and stable. If you want to experience a hassle-free printing, then you should Resolve the Canon Printer Error Code 1660. First check the main reasons that cause:-
1.Inaccurate fitting of the ink cartridges.
2. Misplacement of the ink cartridges.
3. Cracked or closed ink cartridges.
4. If the print device is not possible to recognize the ink tank then you may view Canon Support Code 1660
Full Blog - Canon Support Code 1660
1helpful
Web Replacement error in ricoh mp 9001.
Clear modes(yellow) 1 0 7 hold clear/stop for 5 seconds, and reset the web counter. -Carl
Error code sc546
sc546 is a fuser ready temp problem.
it requires a reset procedure: enter SP mode.touch Copy SP..touch SP DIRECT then press 7807# on the keypad then execute...turn power off and then back on
5helpful
I need THOSHIBA e-studio e-dp-1660 printer driver for windows7
Per Microsoft, this printer is not compatible with windows 7.
4helpful
MY ALARM DID NOT COME WITH INSTALLATION MANUAL AND I DON'T KNOW HOW TO INSTALL IT . IT'S A SP-200
You can obtain a copy of the manual from the following link
http://www.crimestopper.com/Templates/2009_manuals/Alarm/sp-200_ins.pdf
Reset the drum counter
There, there is counter, which it is necessary to throw each 12 thous.. (making at preventive maintenance of the printer). For installation new cartridge it is necessary simultaneously to press shift Ctrl F1.
In connection with extension market copiers Panasonic and with all becoming more frequent questions in Conferences has solved be divided accumulated by information.
The Whole hereinafter presented information pertains to device of the serieses DP
Now about that, what fall into service mode; for entering we press consecutively: key "FUNCTION", key "ORIGINAL SIZE", key "3".
For emergency input in switched off condition hold the keys "FUNCTION" and "STOP" for DP-1515, for the other device - a keys "FUNCTION and "CLEAR", and snap the tumbler of the feeding.
Now we in service mode, possible installthe developer; for what we call at in mode F8-09 and wait the completions of the process for 3 minutes. If this first start or was changed the drum, that executes the procedure F8-14. For leaving from service mode жмем on keys "FUNCTION" simultaneously and "Clear".
Most often used functions of the service mode:
F7 02 General counters mines
F7 03 Counters mines before following preventive maintenance Unset "wrench" is produced by record in cell F7-03 importances 0
F7 06 Counters mines on installed drum
F7 10 Counters mines on the same developer
Top Toshiba Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Norman Weimar
Norman Weimar
Grand Canyon Tech
Grand Canyon Tech
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
