I have the manual here post your email and I will send it to you here are somethings to check in the mean time
12 OPERATING PROBLEMS
12.1 No Power
If the machine appears dead, and there is no response from pressing the power button, then check
the following.
Check the supply voltage and that the machine is plugged in and switched on.
Remove the lid and the console.
With the power supply isolated, physically check all the plug connections to the Motor Control
Module.
With the power supply switched, on check all voltage readings as described in section 6.
Prior to replacing a Motor Control Module, check all resistances of the components as
described in section 7. We also recommended that a visual inspection of the motor and pump
area be carried out. Check for corrosion and signs of water leaking as well as damage that
may have occurred to any of the wiring harnesses.
From the book is this your model??
ECOSMARTTM
PHASE 7
ELECTRONIC WASHING MACHINES
Covering the following product codes
GWL15-US - 96200
do you want the manual you never ansered if that was the model i listed you have??
Well??
you still there???
Where abouts is the inline fuse?
We have checked behind the main panel, but still trying to find where the fuse is......
This is a Smart Drive Excellance. Is that similar to Eco smart?
No thank you. We got a service tech in and he fixed it for $334aud, it was the switch that shorted the PCB out.
have you checked the inline fuse?
