Some phone service providers block the transfer of files. It depends on who your service is through. I know Verizon and Sprint block them when I try to send from my phone to others with those providers.
1.Press and hold the Multifunction button in the middle of a boom headset while the headset is closed. The light will glow blue.2.Open the boom microphone and the blue light should remain on. If not, repeat step 1. 3.On the cell phone, press Menu > Settings > Connection > Bluetooth > Handsfree > New Device 4.Select H700 once a connection is detected. 5.The passkey "0000" is now entered to confirm the connection has been made. 6.The cell phone screen will now read "Bluetooth Connection".
Tips: 1.Provided you set the Bluetooth power to "On" after the initial connection has been made, the phone will automatically re-connect to the headset. 2.To set the Bluetooth power on - Press Menu, Select Settings, then Connections, then Bluetooth link, scroll to Setup and select that. Scroll to Power and chose Change. Scroll to On and press Select. The screen should now read "Changed: Power On". 3.Test Your Connection: Close the headset and watch for cell phone to say "Disconnected". Re-open the headset and the phone should be connected automatically and will now display "Bluetooth Connected".
please give good rating if the solution works. Thanks for using FixYa.
I suggest reducing the size of the SD card to a 512mb and you should have no problem. There have been problems with the 1GB for these phones and I mhave 2 of these phones and they both have 512mb with no problem any larger and they keep giving error messages
you have to make sure within the bluetooth settings on your pc that your pc is discoverable, this is turned off by default, if you are using the software that came with the adapter it must be in the connection settings somehere
i have also had this problem, i have found that if i get the person to send me something first, there name will appear on the list of bluetooth list, when trying to send them something all you then have to do is click on there bluetooth name and it tends to connect.
hope this helps.
