You have an over heat error. you need to test your thermistors, s and lamps for continuity.replace bad parts. then you need to go to service mode and reset the code
That error is for the shift tray motor in your finisher where the copies come out. The tray should move from side to side when you switch the machine off and on. It sounds as if it is binding for some reason.
SC545 and SC 546 are fuser temperatyre error. pls. check thetmistor/ thermostats, connectors if thernistor are deffective replace thermistors. after replacement or checking of this parts do the SC reset. 107 # turn off copier then on after 5 sec.
sc 546 fuser temp changes more than 20 degrees after warm up. clean thermistor if tat dosent work check fuser connector. reset= enter service mode turn copier off wait 5secs then on.
Error Code SC 546 is for fusing & SC 960 is for Current leakage, If u getting it regurally , change the thermistors for error code 546, & for error 960 change drum & charge roller.
Hello sir; Your machine need to reset, the procedure as follow;
1, press "clear mode", "107", then hold down "clear/stop" key, until screen change message to sp mode.
2, turn power off and back on ,machine will in working condition.
enter sp mode with the following combination
yellow key then 1 0 7 and hold down stop till the screen changes go to copy sp then scroll down to 7 datalog and down to 897 sc jam reset and execute the turn off the machine and back on
