Pull the fabric softener dispenser off the agitator, reach down and pull off the white cover (has 2 ears on it), then remove the bolt holding the agitator to the shaft. It then lifts off.
The newer Whirlpool top-loaders have lint screens on the inner tub and not accessible. These are supposed to self-clean during the drain cycle. I've heard that liquid fabric softener and detergent build-up may clog the screens when lint sticks to the gooey screens. Try something that will cut the goo like vinegar or ammonia in a small load level without clothes. Without clothes in the washer, that is.
Older Whirlpool washers have lint filters located above the tub, on the lid opening.
You can check for suction by pulling out the lint screen and holding a piece of paper over it while the dryer is running. If there is suction then it all works correctly. If there is no suction, then there is a clog somewhere inside. You can clear the clog with a long bottle brush or with an attachment from a vacuum cleaner to get inside. If all looks good and still no lint on the screen, the screen may be too short for the dryer and could be a wrong screen for it.
clean out your dryer vent the hose going from your dryer to your house the vent from your laundy room to the out side of the house make sure the vent is as straight and possible and no kinks
also clean your lint screen with soap and water if you use fabric sofener sheets they have a chemical that clogs the screens the watter should flow right thu the lint screen and not puddle up at all
do this asap you are risking damaging your dryer and worse yet your house could catch fire
your problem might be in the actual vent to the outside. If the vent to the outside from the drier has a clog and will need to be cleaned. Without the proper ventallation the clothes will not dry. I suggest pulling the drier out and removeing the vent hose that connects to the outside and clean it. Once this is done you shouldn't have any problems
Step 1
Turn off both the computer and touch screen. This way, you
can see everything that needs to be cleaned. Some touch screen
applications has a cleaning mode which turns off the screen for the
specific purpose of cleaning. However, the monitor's brightness can make
you miss some areas.
Step 2
Wet a soft, lint-free or microfiber cloth with distilled
water. Wring out as much water as you can. Make sure the cloth is damp
but not wet. Wipe the screen in a gentle motion to remove dust, oil, or
fingerprint smudges off.
Step 3
Another option is to use a screen cleaner kit that includes
antistatic wipes. You can buy this at various electronic or online
stores. Spray a little solution on a wipe then rub it gently across the
screen.
Step 4
Finish cleaning the touch screen with a dry lint-free cloth
to wipe any excess moisture, then turn it back on.
If you found this information helpful, please give me a big thumbs-up when you rate my answer. Thank you.
There is a fine screen on the bottom of the inner tub under the agitator. It is self cleaning every time it spins out. If you use too much fabric softener, the screen can get clogged. Fabric softener is hard to clean off and the screen is pretty delicate.
This is common on all dryers. Not lint screen will catch all the lint although some are better than others. If you haven't already, you will need to clean or have your home vent cleaned (with a brush that goes all the way through the vent). If vent is not cleaned the lint will back up all the way into your dryer and cause a mess. You have stated your vent goes up to your roof so you will need to clean it every 6mths to 1yr. Aside from this there is no fix that I am aware of. Please rate me after reading this.
My wife has a Bosch Premium dryer that had drying problems. The lint filter would get cleaned but the machine still did not operate correctly, as you explained above. Her machine was made in 2005 and the lint screen, the plastic slotted unit in front of the lint filter was the problem. It gets clogged up with hair/lint that never makes it to the filter. I tried a shop vac to vacuum it but the problem was still there. Get a pistol cleaning kit for a 22 cal gun. Pull the lint filter out & then take the pistol rod and insert it from the drum side into each slot and pull out the tons of lint. Pull the lint off the rod when done and take a flame to burn the rest off as the rod is a brass brush with small wires on it.
Besides drying clothes, dryers also remove lint. This fine, fuzzy material can cause trouble because it blocks dryer lint traps, clogs vents, and fills blowers. Lint can also gather around and in the tracks of the drum rollers, or in and under the pulleys and the drive belt. The result is poor clothes drying or -- sometimes -- no drying. To avoid lint problems, clean out the dryer's lint trap system every time you use the dryer. To clean the lint screen, remove it from the unit. The screen may be located near or under the door sill, or in the top of the dryer near the control panel. It can usually be removed by pulling it up and out of its housing. Remove the accumulated lint to clear the screen; then replace the screen. The exhaust vent also collects lint. Vent maintenance involves cleaning the lint from a screen in the dryer's vent exhaust collar and/or at the end of the exhaust vent where it sticks out through a basement window or through an exterior wall. To clean the screen, remove the clamp that holds the vent to the collar, or back out the screws that hold the vent to the collar, or pull the vent straight off an extended collar. Clean the screen thoroughly and replace it in the vent assembly. To clean the vent itself, use a vent-cleaning brush (available at hardware stores) to pull out any lint deposits. Also check the vent run to make sure that the vent piping or tubing isn't loose at the joints, or -- in the case of flexible plastic venting -- isn't sagging between hanging brackets. Breaks or sags cause undue strain on the dryer's blower system, and can cause drying problems. If the vent pipe or tubing has become clogged with lint, remove the lint by pushing a garden hose or a drain-and-trap auger through the vent to a convenient joint. Disassemble the joint to remove the debris. With this procedure, it isn't necessary to disassemble the entire vent to find the blockage.You can head off problems before they become too serious by providing routine maintenance for your dryer's door gasket, thermostat, timer, and other frequently used parts. Let's discuss how to service these important components in the next section.
THANK U.. RATE IT...
No. The accumulation of lint in the dryer screen generally doesn't have anything to do the amount that ends up INSIDE your dryer. Too little lint is not a bad sign. It's dependent upon the type of clothing you are drying as well. If the clothes are not "lint givers" (like cottons and wools), you generally won't see a lot of lint in the dryer screen. Dryer screens are not perfect, either and some lint always gets through. As long as there are no holes in the screen and you have it seated correctly, and you clean it after each use, you shouldn't have any problems.
What affects dryer performance the most, is your vent hose and routine cleaning. The simple rule of thumb is: The SHORTER and STRAIGHTER the vent hose the BETTER. The vent hose should also be cleaned thoroughly periodically. I recommend once per season. That's about 4 times per year. What causes the lint to back up into a dryer is when the vent hose becomes kinked or clogged. The lint is mixed with moist air when it leaves the dryer. If it has no where to go, it starts to accumulate and stick in areas of the vent hose that are sagging, or at tight bends. Eventually, the vent becomes so restricted that the lint ends up inside your dryer. This causes the heating circuits to overheat to eventual failure. Not to mention, accumulations of lint inside a dryer can cause a fire. I have personally inspected dryers that were so full of lint that the dryer hose contained about a gallon of water from condensation and the inside showed evidence of multiple fires. If you need further info, I have an article I wrote up explaining all of this under "Tips and Tricks" under my profile. I hope this helps you.
