Question about Cuisinart ICE-40 Flavor Duo Frozen Yogurt 1 Quart Ice Cream Maker
Ice cream won't thicken
Did one batch..worked great. Second batch ran for 20 minutes...the ice cream will not thicken. The machine is running...ingredients were cold, bowls were frozen but nothing...just sloshing around. Help!
  • Anonymous Jan 28, 2010
    It does not use ice or salt.
  • 1,389 Answers
DID YOU USE SALT IN THE ICE ??
Posted on Jan 28, 2010
  • Jay Finke
    Jay Finke Jan 28, 2010
    DID YOU CHILL THE MIXTUREB
6ya staff
SOURCE:
My first batch of vanilla ice cream came out grainy. Not smooth or glossy. Pieces taste like custard base. LELLO 4080 Please help. Silvia
Hello, Silvia -
From a review of a Lello 4070 model ice cream maker:
(Quote)
Watch it closely to avoid over mixing (makes for a grainy texture) the first time you try a new recipe
(End quote)
Source:
http://www.home-gem.com/products/home-kitchen/kitchen-dining/small-appliances/ice-cream-machines/9168-lello-4070-gelato-junior.html#feedback-rate
http://icecreammakersfaq.blogspot.com.au/2013/07/
(Quote)
Too Grainy, Icy or Hard - If the cranking mechanism becomes too hard to turn in less than 20 minutes on manual models, or if motor stalls in less than 20 minutes on electric models, resulting in coarse or an inconsistent texture of ice cream, the saltwater became too cold too fast. In this case, you used too much salt and the ice cream froze too fast on the edge of the can, and/or you did not used crushed ice.
Recipe Hint - Preparing the ice cream mixture the day before makes smoother ice cream and increases the yield.
(End quote)
Best wishes.
Apr 27, 2018 | Lello Ice Cream Makers
Ice cream won't set up
The ice machine is a little more complicated then what it look like first you need to know if is any air filter. should be there, some where if no air filter do not try to fix the machine your self this type of equipment contains refrigerant and high voltage should be handle by an experienced certain devices hold electrical charges even unplug hope this is usefully.
qualified technician may little but could be dangerous
Aug 12, 2012 | Salton ICM15 BIG CHILL 1.5 Quart Ice Cream...
Problem with 2 Musso Pola Machines
Depending on the ingredients, it could take 40 minutes to make a batch. Make sure you mixture is very cold before it goes into the unit by chilling in the coldest part of the refrigerator until very cold. If anything less than a very cold mixture goes into the unit, the freezing time will be quite long. The outside of the unit will not feel cold, just the inner wall of the bowl. Also, if your recipe includes any alcohol, this will inhibit the freezing process.
Mar 15, 2010 | Musso Stainless Steel Pola Ice Cream Maker
Ice cream maker doesn't chill
The machine must be upright for 24 hours before using it.
If it was stored on its side or upside down you MUST wait 24 hours with the machine in the correct upright position. The 'person' who delivered mine made sure he tumbled it over and over again scanning shipping labels even though it said everywhere fragile and this side up.
If the machine does not work at cooling after 24 hours there is a problem and it should be returned.
Do not expect rock hard ice cream, but thick scoop-able medium firm soft-serve is easy to get as a result. A few hours in the freezer will harden it more.
Nov 08, 2009 | Cuisinart ICE-50BC 1.5 Quart Ice Cream...
Ice-cream maker doesn't fit together
Do a 1/2 to 2/3 batch. Put a book and a soup can on top of the mixing arm to keep it down.
The machine does make wonderful Ice cream, however it is noisy and fiddly. Do not try the full batch as it just doesn't work. I find doing 2 half size batches works best. Also find a spare room to run the noisy beast in.
Jun 16, 2009 | Cuisinart ICE-50BC 1.5 Quart Ice Cream...
Put the ice cream bowl in the dishwasher
The only way to tell is by putting it in the freezer for 24 hours, and then trying to make a batch of ice cream. If it doesn't freeze or make the ice cream properly, then you will need to get a replacement bowl from Cuisinart - they are available.
-Tha Mp3 Doctor
Aug 11, 2008 | Cuisinart ICE-20 Automatic Frozen Yogurt...
Cuisinart ICE-20 AND TURNING PROBLEM
The problem is either the mixing paddle itself or the lid that it fits into - both parts can be ordered from Cuisinart.
Aug 09, 2008 | Cuisinart ICE-20 Automatic Frozen Yogurt...
Do you have any recipe for milk free ice cream? For lactose intollerant diet?? Perhaps Almond Milk or Soy Milk.
Here are some of the useful steps to make a milk free ice cream.
1.) Microwave the chocolate and butter-substitute for thirty seconds in a microwave-safe bowl.
2.) Add a dash of salt, and a splash of vanilla extract to taste.
3.) Put a scoop of marshmallow fluff into the bowl and stir it in thoroughly.
4.) Remove the spoon, lick it clean, and wait up to 5 minutes for your mixture to become room temperature.
5.) Place it in the freezer for 50 minutes, remove, and if it is still not frozen well, then stir it thoroughly and place it back in the freezer for another 20 minutes.
Jun 26, 2008 | Rival 8550-X 5 Quart Ice Cream Maker
Ice Cream won't set up
Carri, Can you provide more information? What did you change in the recipes? How old is the machine? What was the temperature around you? Did you run three batches or more right in a row? -j.
Jun 19, 2007 | Rival 8704 4 Quart Ice Cream Maker
Cuisinart ICE-40 Flavor Duo Frozen Yogurt 1 Quart Ice Cream Maker Logo
595 people viewed this question
Top Cuisinart Ice Cream Makers Experts
Marvin
Marvin
Lawrence Oravetz
Are you a Cuisinart Ice Cream Maker Expert? Answer questions, earn points and help others
