After 30 seconds if the control does not detect water entering the machin then the water valve will be shut off and the error code show.
also:
If the control has turned the water valves on and 8 minutes pass and the flow meter has measured roughly 10.1/2 gallons of watergoing through it, but hasnt detected the pressure switch being triped, the water valve will shut off and the fh error code will blink
First push the PAUSE/CANCEL key twice to clear the control
If no water in the unit do this: - Make sure the valves at the water source are turned on fully.
Inspect for plugged or kinked inlet hoses or maybe plugged screens in the inlet valves
Also inspect the water valves operation
If there is water in the washer: - Inspect the drain pump, and the pressure switch hose for any kinks or rips. also check for proper connections with that hose to the tub and pressure switch.
may be a siphon problem read your manual on that.
Check all wireing harness connections to the Water valves,pressure switch, drain pump, flow meter, and the ccu or cental control unit
Inspect all hoses for any leaks
Replace the failed component if found ...
hope this helps
Thank you for contacting fixya.com.
FH
error code means low water inflow. In this error washer is not filling when the
fill valve opens.
To clear the error please follow the bellow instructions:-
Press the "Stop" button twice with your finger. This cancels the
cycle and stops the washer. Unplug the power cord from the wall outlet.Turn the
water shut off valves clockwise to stop the water flow to the washer through
the supply hoses. Pull the washer away from the wall enough that you can access
the hose connections at the back of the washer.
Set
a bucket under the area of the hose connections. Unscrew the hose connections
from the back of the washer. If necessary, use a pair of slip joint pliers to
help start the connections turning until you can turn them by hand. Set the
ends of the hoses inside the bucket.Inspect the screens on the inlet ports on
the back of the washer where the hoses connect. Sediment and other debris can
block these screens, causing fill problems. Clean the screen with an old
toothbrush.
Thread
the hoses back onto the washer. Look for kinks in the hoses. Kinks cut off
water supply to the washer which causes the FH error code. Once you connect the
hoses, turn the water supply valves counter-clockwise to supply water to the
washer. Move the bucket away from the washer and push the washer back into its
working position.Plug the power cord back into the outlet and start the wash
cycle again. If the FH error code comes up again, call a service repairman. If
the hoses have no kinks and the inlet screens are clean, there is a problem
with either the pressure switch or the flow meter.
Please get back to us if
you have further query else please accept the suggestion.
