Philips 50 Amblight, The TV is only used occasionally in a media room. The problem first appeared in Dec, It is connected to a Directv HD receiver.
The Tv turns on, then goes immediately off and the green power light starts flashing red. The last time, I unplugged the TV for about 3 days and then it started to work again. After it started working I updated the software as provided by Philips from the website, but this has happened again. I unplugged it over night, and it tried to turn on, but then went back to the red flashing light.
SOURCE: Phillips 42pfl5332d Wont turn on!! BRAND NEW!!
Same F'ing problem. First 6 digits are YA3B07
SOURCE: 42" philips plasma
when a television turns off by itself and flashes as you say, it indicates that there is a problem inside the tv. If you keep trying to turn it on you may do more damage. It could be something as simple as a faulty fuse inside. If you have no expierience with electrics I suggest you get it checked out by a professional. I had a similar problem with another tele model and it was the fuse in the back of the tele that needed changing. I did try to this on my own but unfortunatley didn't have the right fuse so i took it to a repair shop and he done it really quickly.
SOURCE: Philips 42 inch HDTV - "FlatTV" Plasma -- does not turn on.
I had the Same issue. on a 50PF9431D/37 set. Many Plasma Set's use a LJ44-00118A PS-505-PH Power supply from Samsung. Known to have this common problem. If you can, or have a friend that can Solder components?. Unplug your set remove the back panel & locate your power supply. It will be the PCB in the center of the set just above the Video/Audio connections. http://www.shopjimmy.com/power-supply-unit-lj44-00118a-from-philips-50mf231d-40.htm. Is a Link to a photo of the PCB. Make a note of the locations of all cable connections then unplug them all. Un-install PCB, Check all Fuse first. I believe their is 5 or 6 of them on the PCB. Then replace the two 3300uf 10v 105C Radial capacitors at C8060 & C8059. Look to see if the Caps are deformed and or split at the top. The location of the caps are in the Lower bottom edge of the PCB. A local shop may Carrie them if not, digi-key has them. Part # http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=493-1754-ND. Total cost was $7 with S/H.
SOURCE: philips 50 amblight keeps returning to menu screen
I'd open the TV by pulling the back cover and then disconnect the buttons bar cable to see if the problem is there.
This is the #1 thing I would do in an attempt to isolate the most likely source of the effect.
Let us know what happens.
