Malber WD1000 Front Load Washer/Dryer Logo
Posted on Jan 29, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I just bought the Malber WD1000 Washer/Dryer Combo but the cables are damaged and need to replace them
Anonymous
Level 2:
New Friend:
  • Expert 105 Answers
  • Posted on Jan 29, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
105
Questions
Helped
25751
Points
296
Contact where you bought it and they should replace the cables under warranty.
How do you get the water to drain in the Malber WD100 washer/dryer combo?
Hi. I''m assuming you are referring to a WD1000.
To initiate the drain cycle: Rotate far right knob CLOCKWISE to Position 4. It may take 30-45 seconds to recognize the knob's new position, but then it will begin an 11 minute Slow Tumble/Pump Out cycle. During this cycle you'll see the internal drum slowly rotate CW for 60 seconds, pause, then rotate CCW for 5 secs - then repeat. All this time the pump will run and you'll hear water running down the drain. When you hear no more water you can rotate same knob to "straight up", and stop the machine. To turn power off, press the rightmost button.
4helpful
2answers
Malber WD1000
door handle broke at plastic insert. Looking for replacement parts.
Malber wd1000
Two of the dials are dryer settings. There is only one washer dial, which basically controls the length of the wash and rinses, etc.
How much clorox 2 and fabric softener
DONT USE CLOROXE 2 ITS NO GOOD make sure you wash on cold / cold that makes the colr last and no shrinkingit takes a full lid on full load half lid on medium and 1/4 on small load same with scoops
Gasket for Cleanout at bottom of Malber WD1000
WD1000 gaskets are in stock and available for immediate delivery from Malber USA. ([email protected])
Getting the dryer to start after turning it off.
Suggestion: Switch off wall plug and restart to dry.
Top Malber Washing Machines Experts
vince
john h
Are you a Malber Washing Machine Expert? Answer questions, earn points and help others
