Intuit QuickBooks Pro 2007 Full Version (299116) Logo
Posted on Jan 29, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Code: 80070057 - Intuit QuickBooks Pro 2007 Full Version (299116)
will joe
Level 2:
Sergeant:
  • Intuit Expert 321 Answers
  • Posted on Oct 10, 2022
will joe
Intuit Expert
Level 2:
Sergeant:
Answers
321
Questions
0
Helped
135990
Points
930
Make sure QuickBooks has sufficient permissions so it can run without any problems.
  1. Close QuickBooks Desktop.
  2. Right-click the QuickBooks icon.
  3. Select Run as administrator.
  4. If your company file did not open automatically, select the company file, then select Open.
Regards,
Will
Anonymous
Level 1:
New Friend:
  • Contributor 34 Answers
  • Posted on Feb 02, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
34
Questions
0
Helped
12155
Points
52
Is this suppose to be an error code?
Try this site:
http://www.blocktax.com/quickbooks-errors.htm
2answers
Does anybody know how to work on a 50lb milnor washer
Do you have any information about What does QuickBooks Error 80070057 Mean and How to Fix it?
No worries, we are creating an article for you that will explain all these things. Just visit us and read the complete article.
Article details:https://qbsenterprisesupport.com/quickbooks-error-80070057
Aug 16, 2021 • The Optics
2answers
U7361-1253-80070057 error code
Found on Google: you experience the error code U7361-1253-80070057 on your Windows 10 computer, it typically points to an issue with stored information or settings on the device. Follow the troubleshooting steps below to resolve the issue. Right click on the volume icon in the lower right hand corner.
Error code 80070057 on Lumina 630 cyan
There are a few solutions to this:
Firstly check the date settings on the phone to ensure they are correct.
Second, check your passwords and try changing them to see if that resolves the error.
third, delete the accounts from your phone and reset them up.
CANNOT OPEN QUICKBOOKS
According to intuit Error : 80070057 PARAMETER INCORRECT is most common problem. for knowing its cause and step wise solution follow Error 80070057 the parameter is incorrect or You do not have sufficient... and if need any guidance while understanding any technical prospect follow Intuit Help by Intuit Certified Technician .
3answers
Turbotax 2008
Hello There, I found this in their FAQ Guide. Hope this resolves your problems, I know it is a bit of a read. Good Luck!!
What is happening?
Double-clicking on a backup, portable company file, or a file with an extension other than .qbw, the following error occurs:
An error occurred when QuickBooks tried to create, open, or use the company file. Please try again. If the problem persists, contact Intuit Technical Support and provide them with the following error codes: (-6150,-1006).
Or, if you attempt to double-click the data file without QuickBooks open, the following error occurs:
There was an unexpected error reported while trying to run QuickBooks with company file "path location". Error code 80070057.
Note: More than one error message that includes the error code 80070057 exists. If this is not the exact wording of your error message please refer to one of these other documents:
Error: 80070057 parameter is incorrect" when clicking on a QBB, QBM, QBW, NT, or TLG file from a Google Search Timeline
Error: 80070057 parameter is incorrect" when clicking on a QBB, QBM, NT, or TLG file from a Google Search Timeline
Error: 80070057, the parameter is incorrect. There was an unexpected error reported while trying to run QuickBooks with company file [path and name]
Error: 80070057 the parameter is incorrect" and "You do not have sufficient permissions to delete files...
If your Error 80070057 is different than the ones displayed, perform a new Search.
Why is this happening:
QuickBooks cannot read the company file because the QuickBooks file extension was changed or is the wrong type (.qbm, .qbb, .qbx).
This error can also occur during conversion or creation of a backup or portable company file if QuickBooks detects data damage in the company file.
This error may possibly occur if the QuickBooks installation is damaged.
This error can also be caused by attempting to open the portable company file (.qbm) without having QuickBooks open.
How to fix the problem:
Verify that the file extension displays company name.qbw and not a shortcut.
Copy the company file, change the extension to .qbm, .qbb, or .qbx, and follow the appropriate steps to open a portable file, backup, or accountant's review.
If the error occurs during the conversion or creation of a backup or portable company file, run the Verify utility to check the file for data damage. If it finds damage, run the Rebuild utility.
Repair the QuickBooks installation.
Uninstall, and then reinstall QuickBooks.
Sound
Dear sir/madam,
Download the latest Direct X maybe? Not sure.
Thanks
good luck
Dont forget to rate the solution
Top Intuit Computers & Internet Experts
Ngoro
ADMIN Andrew
ADMIN Andrew
Are you an Intuit Computer and Internet Expert? Answer questions, earn points and help others
