Question about Apple iPhone Smartphone
My Iphone is not responding to my touch when I am trying to input my PIN. What is happening? I received a new Iphone and it was working very well. But I left it in my bag with another phone and when I try to access it, it would not respond. I turned it off and back on and I got the welcome screen but it is not responding to my touch when I try to put the PIN in.
    New Friend:
  • 19 Answers
Hold the power button and home button at the same time for about ten seconds... :)
Posted on Jan 30, 2010
6ya staff
SOURCE:
Iphone 3gs wont work. white flashlight screen?? please help
If iPhone doesn't appear in iTunes or you can't sync iPhone
  1. The iPhone battery might need to be recharged. For information about charging iPhone, see "Charging the Battery" in the iPhone User's Guide.
  2. If that doesn't work, disconnect other USB devices from your computer and connect iPhone to a different USB 2.0 port on your computer (not on your keyboard).
  3. If that doesn't work, turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for a few seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
    Note: If you enter the SIM PIN incorrectly three times, you may need to contact your carrier for a Personal Unlocking Key (PUK) to enable your SIM card again.
  4. If that doesn't work, restart your computer and reconnect iPhone to your computer.
  5. If that doesn't work, download and install (or reinstall) the latest version of iTunes.
If you can't make or receive calls, send or receive text messages, or access email or the web
  1. Check the cell signal indicator in the status bar at the top of the screen. If there are no bars, or if it says "No service," try moving to a different location. If you're indoors, try going outdoors or moving closer to a window.
  2. Check to make sure you’re in an area with network coverage. Go to your carrier's website to see network coverage areas.
  3. Make sure airplane mode isn't on. From the Home screen choose Settings, then turn Airplane Mode off.
  4. If that doesn't work, turn airplane mode on, wait 15 seconds, then turn airplane mode off again.
  5. Make sure to include an area code for every phone number in your contacts list that you use to send or receive text messages.
  6. If that doesn't work, turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for a few seconds until a red slider appears, then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
  7. If that doesn't work, there may be an issue with your wireless service. Call your carrier or go to your carrier's website.
  8. If that doesn't work, restore the iPhone software. See Backing up, updating, and restoring your iPhone and iPod touch software or see "Updating and Restoring iPhone Software" in the iPhone User's Guide.
MMS: Original iPhone does not support MMS. MMS is available on iPhone 3G and iPhone 3GS if it is supported by the wireless carrier. For more information, please see iPhone: System requirements for MMS.
If iPhone won't turn on, or the display freezes or doesn't respond See iPhone and iPod touch: Frozen and unresponsive for information on addressing these symptoms.
  1. iPhone OS 2.x and earlier: Press and hold the Home button until the application quits.
    iPhone OS 3.x and later: Press and hold the Sleep/Wake button until the red slider appears, then press and hold the Home button until the application quits.
  2. If that doesn't work, turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for a few seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
  3. If that doesn't work, reset iPhone. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears.
If iPhone continues to freeze or not respond after you reset it
  1. Reset iPhone settings. From the Home screen choose Settings > General > Reset > Reset All Settings. All your preferences are reset, but no data or media is deleted.
  2. If that doesn't work, reset iPhone. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears restore the iPhone software. See Backing up, updating and restoring your iPhone and iPod touch software.
Jun 28, 2010 | Apple iPhone Smartphone
Iphone touch screen not working
hey meybe a software that you install in your iphone is that one causing it, try to un install some, and maybe theres not enought space for your iphone, try to delete some.hope it solved your problem.
Sep 30, 2009 | Apple iPhone Smartphone
My iphone wont respond to touch i cant use it
try hard reset (hold down the power button and the central button until you see Apple logo on screen). If this wont help then use RESTORE.
Aug 25, 2009 | Apple iPhone 3G Black Smartphone
My HTC Touch HD touchscreen does not allow to input pin
Hi Matt, Is your touchscreen not responding? Try put your sim to other phone and disabble pin.
May 12, 2009 | HTC Touch HD Smartphone
My iPhone touch screen is not responding at all
It sounds like a hardware problem, not software. I would try calling 1800myiphone(180069474663). Yes that is one digit more than normal but it is a specific iphone help line. I've had to use it before.
Aug 07, 2008 | Apple iPhone Smartphone
just try to remove the battery as well and restart again your iphone. if the problem persist go to your nearest iphone service center or to your Apple distributor.
Jul 28, 2008 | Apple iPhone Smartphone
Iphone screen problems
Had this same thing happen with 2 of my apple iphones, but it was the bottom half of my touch screen that wouldn't work. Took in back to apple. They didn't even bother trying to fix the problem, said it happens all the time, and it has something to do with the touch screen not laying correctly against the plastic, so it can't read your touch. They just took my phone, and handed me a new phone each time, and at no cost, of course. I guess it's just a flaw that they had not worked out before putting them on the market. Make sure you download all your settings, phone #'s, music, and pictures by syncing it with your computer through itunes before you take it in because you will have to do a restore once you get your new phone. Also, one person told me it could be due to the plastic film you add to the screen of the iphone, if you did add a plastic screen. It can cause problems with the touch screen. I took it off of my phone, but it didn't help at all. I, also, did a complete restore on the phone, but that didn't help, either. Just take it back to apple, or send it in, and they will give you a whole new phone with no questions asked. Good luck!
Jun 06, 2008 | Apple iPhone Smartphone
Iphone touch-screen
sir whats ur model\????
May 28, 2008 | Apple iPhone Smartphone
Iphone touchscreen is not working i am not able to open application
my first guess would be to advise you to repair the software by reset it. go in setting, general and select reset ( make sure you save all your file first) let me know what happen!
Apr 09, 2008 | Apple iPhone Smartphone
Apple iPhone Smartphone Logo
290 people viewed this question
Top Apple Cell Phones Experts
Ekse
Marvin
Marvin
Travis
Travis
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
