Question about Apple iPhone 3G
I try to restore my iphone 3g it went to recovery mode then after a while it shows a green and blue sreen wtih apple logo anyone plzzzzzzzzzzz help
  • Anonymous Jan 30, 2010
    i did it but it show the message that the iphone could not be restored. an unknown error occurred(1603)
  • 3 Answers
Try to restore with IREB.. may b it can help u. from google u can download iREB.
Posted on May 11, 2010
    New Friend:
  • 19 Answers
Hold the home button... plug your usb cord to your computer, the plug the cord to your iphone. WHILE holding the home button still! it may clear it up with itunes.
Posted on Jan 30, 2010
6ya staff
SOURCE:
Error 1015 in iTunes iphone 3g Model no a1241...
  1. Disconnect the USB cable from your iPhone, but leave the other side connected to your Mac or PC
  2. Launch iTunes
  3. Press and hold down the Home and Sleep/Power button on the top of the iPhone to turn off the iPhone
  4. Press and continue to hold the Home Button while you reconnect the USB cable to your iPhone, this will cause the iPhone to turn on
  5. Continue to hold the Home button until an alert message in iTunes informing you that an iPhone in recovery mode has been detected. Your iPhone is now in recovery mode. If you have not launched iTunes, you will see the familiar screen of the USB cable pointing at the iTunes logo signaling to connect the iPhone to iTunes to start recovery.
    Once you're in recovery mode, you can either restore the iPhone or adjust the firmware as necessary.
    After restoring or upgrading firmware, your iPhone will automatically reboot and exit recovery mode on it's own.
Sep 05, 2015 | Apple Cell Phones
Iphone 3gs stopped working. just shows apple logo then turns itself off
try irecovery or ireb to get it out
it can be found on ih8sonw
recommended : ireb, easyrecovery 2.5, tinu umbrella (use it just to kick it out of recovery loop)
if that doesnt solve the problem then restore the firmware through the itunes..
just connect it to itunes and it will detect it in recovery mode, if it doesnt then put your phone in DFU mode and then restore it.
the method to put it in DFU mode can be found on GOOGLE..
Feb 28, 2011 | Apple iPhone 3G
I reset my iphone 3g and now its been frozen for 2 days, it only shows start-up apple logo. please help!
Do a hard reset.
  1. Press-hold the Home button (big circle below the screen) and the Sleep/Wake button (on top of the iPhone) simultaneously.
  2. Continue holding both buttons (Ignore the "Slide to power off") until the iPhone shuts off and begins to restart.
  3. You may let go when you see the silver Apple logo.
  4. You have completed a hard reset successfully.
  5. Don't be alarmed that it takes quite a while to load from the Apple logo to the main screen. This is normal.
If this does not work, put into recovery mode and restore from itunes.
Step One
Open iTunes and connect the iPhone to your Mac.
Step Two
Press and hold the Home button and the Sleep/Wake button at the same time.
Step Three
As soon as the screen goes black release the Sleep/Wake button. Continue holding the home button until you iTunes pops up a message telling you that it has detected an iPhone in recovery mode.
The iPhone will look like this:
Iphone 3g stuck in "recovery mode" (black screen
To reset your iPhone settings,
picexporterror From the home screen, Tap Settings > General > Reset > Reset All Settings.
Still having problems?
Try deleting all the existing settings.
Note: The step given below will delete all the data on your iPhone. It will also give a reset to your settings.
From the home screen, Tap Settings > General > Reset > Erase All Contents and Settings.
Or:
If iPhone won't turn on, or the display freezes or doesn't respond
  1. Press and hold the Home button for at least ten seconds, until the application you were using quits.
  2. If that doesn't work, turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for 10 seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
  3. If that doesn't work, reset iPhone. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears
Let me know if this helps or not, there are other resets available :
If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Feb 19, 2011 | Apple iPhone 3G
My Apple IPhone 3G Screen just went blank. It sync's to my ITunes and I restored it but in never turned back on. Any suggestions?
Sorry to read about your problem, I hope this helps you out.
you will have to put the phone in the DFU mode and restore with itunes
To put the iPhone into DFU mode so you can do an iTunes firmware restore follow these steps:
Step One
Step Two
Step Three
After exactly 10 seconds release the Sleep/Wake button. Continue holding the home button until you iTunes pops up a message telling you that it has detected an iPhone in recovery mode.
The iPhone screen will remain black like this:
NOTE***: It may take a few attempts to get your iPhone into DFU mode. Generally, I hold down both buttons then release the Home button just before I think the Apple logo would appear. If you are still holding both buttons down and you see the Apple logo you are holding them down for too long!
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
Dec 27, 2010 | Apple iPhone 3G
Stop in apple logo
Try to restore in dfu mode -plug iphone into itunes
-Press and hold the home button and the sleep/wake button (on top of phone) at the same time -After 10 seconds release the power button. keep holding the home button until itunes shows up with a message that says "itunes has detected an iphone in recovery mode" -click "ok" and restore as usual
Dec 26, 2010 | Apple iPhone 3G
My iphone 3G does not starting up it simply shows the apple logo
U PLS do as i say ..............Open iTunes and connect the iPhone to your Mac or PC
Step Two
Step Three
Jul 16, 2009 | Apple iPhone 3G
Iphone 3G Erase All content and settings problem
DFU means Device Firmware Update. If a restore using Recovery Mode doesn't work you will want to use DFU Mode as a last resort. When placing your iPhone into DFU Mode it does not load the OS before attempting the restore
videothumb.pngWatch the Video!
For your convenience this tutorial is available in video format also. Click the Watch It button to view the tutorial!
Step One
Step Two
Step Three
Jul 02, 2009 | Apple iPhone 3G
Apple iPhone 3G Logo
140 people viewed this question
Top Apple Cell Phones Experts
Ekse
Marvin
Marvin
Travis
Travis
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
