Datamax DMX I-4206 Printer Logo
Posted on Jan 29, 2010
Wrinkles in ribbon using Datamax H-4212 printer
I can print 3.31" labels using 4" wide ribbon with minimal ribbon wrinkle. When I print 2" wide label with 4.25 red or blue ribbon I get a lot of wrinkle. Can mismatched widths of label and ribbon cause wrinkle? Or is the some other problem i may be missing?
Thanks,
George
Anonymous
Level 1:
Problem Solver:
  • Contributor 10 Answers
  • Posted on Apr 15, 2010
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
10
Questions
0
Helped
7094
Points
13
Definitely. possible solution match the width of your label and ribbon. if your ribbon is wider for .5 inch it should be good.
1. check your spindle alignment, printhead alignment and rotate the green knob on the printhead while printing so that you'll see the difference.
Barcode scanner won't read printed labels
1. The printhead in your printer might be scratched (evidenced by thin white streaks through your print). This is common, and the most likely cause. Printhead must be replaced.
2. Material might be stuck on your printhead (usually evidenced by wide white streak vertically through print). Printing surface of printhead can be cleaned with rubbing alcohol and cotton ball.
3. The ribbon might be wrinkling due to uneven tension, producing intermittent diagonal streaks in your print. This is somewhat common, but doesn't fit your description as well as 1 & 2 above. Mechanical adjustment and/or proper media loading solves ribbon wrinkles.
4. Poor pressure and/or printhead alignment. Evidenced by grainy, light or no print on one side or the other of the media. This is somewhat common, but doesn't fit your description as well as 1 & 2 above. Mechanical adjustment solves printhead pressure and alignment issues.
We are getting white vertical lines running through our barcode label. it looks like printer ribbon is wrinkling when printing them on long runs. How can we stop this
When you have this problem you need to determine if the ribbon is wrinkling before or after the head. If it is before the head then you need to adjust the bar prior to the head. There should be a phillips head screw there and directly behind it there is an adjustment. Loosen the screw and then move the bar (it is slightly arc'd) so it smooths out the ribbon. This is the least likely suspect. Most likely the head is not square. If the head is not square with the roller below it will cause the ribbon to "dance" as I call it. It will slowly move over then jump back to its rightful position. Or it could just wrinkle. If this is the case and your print looks good then you can adjust the ribbon bar right where the ribbon comes out of the head. There are two screws at the top. Loosen both of them and this adjustment bar will slide all the way back. Once this goes back. Manually manupulate it until it smooths out the ribbon. Once you manually figure out where it is smooth then tighten the screws back up. Feed a few labels and see if the ribbon is smooth.
We are having trouble while printing bar coded labels, there are streaks going across the label what can stop this from happening?
If streaks are perfectly vertical and always present, probably your printhead is scratched and needs to be replaced. Unless the streaks are diagonal and intermittent - then you need adjustment for ribbon wrinkle.
Printheads
HELLO!! MY EQUIPMENT IS DATAMAX DMX-1-4212 AND TO THE MOMENT TO STAMP THE RIBON WRINKLES AND ORDERS THE IMPRESSION WITH STRIPES
poor tension on the rollers?
try pulling the ribbon during stamping, if this corrects it then you may need a tech to come and reseat some drive gears.
Z4MPlus Ribbon wrinkles causing lines diagonally across label.
Could be down to tension on the ribbon roller/spool. Check to see if you have pulled out the end part of the spool (black bit) that should ensure there is back tension on the ribbon.
Thermal Ribbon has a wrinkle
The thermal print head is damaged. You can try to clean it with a thermal printer head cleaner. That will only help if it is just clogged up with thermal print ink.
Printer Ribbon has a wrinkle in it
Remove the ribbon and try to remove the crease. Check the printhead for obstructions. You may have to open up both halves of the ribbon cartridge to look for jams or obstructions.
Zebra Z4MPlus Ribbon Wrinkles
I changed the print head, and the issue was solved.
Datamax I-CLASS DMX-I-4212
Printer ribbon has a wrinkle and it transfers to the label in the form of a blank line accross the ribbon.
Ribbon wrinkles when printing barcodes
This is usually caused by temperature of the thermal print head. This is found in the printing preferences of the printer.
Top Datamax Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Are you a Datamax Office Equipment and Supply Expert? Answer questions, earn points and help others
