Expert
- Posted on Jan 30, 2010
Re: How do i remove the drum on a maytag top-loading...
If you want to remove the drum of your maytag wahser follow this procedure:
- Disconnect the power supply to the Maytag dryer by unplugging it from the wall outlet.
Use a screwdriver to remove the three screws located at the top of the control console.
Pull
the control console forward to release the tabs that hold it to the
Maytag dryer top. Maneuver the control panel out of your way without
disconnecting any wires.
Use
a putty knife inserted between the top and front panel to disengage the
retaining clips that secure the top panel of the Maytag dryer. Lift the
top panel up, and remove it from the dryer.
Use
needle nose pliers to remove the wires from the door switch terminals.
The door switch is located just inside the front right corner. Grasp
the wire leads with the pliers and pull them off the terminals.
Use
a screwdriver to remove the retaining screws that hold the front and
side panels together on the Maytag dryer. Lift the front panel up and
out of the work area.
Use
a screwdriver to remove the Maytag dryer drum light lens screw. Press
the locking tabs on the light socket, and remove it from the cavity of
the drum.
Use a socket wrench to remove the four retaining bolts that secure the drum bulkhead to the sides of the Maytag dryer.
Reach
your hand beside the drum and the motor, and push the idler pulley
forward to release tension on the belt. Make notes of how the belt is
routed on the pulleys, and then remove the belt from the motor pulley
and idler pulley.
Grab the belt with one hand, and the Maytag dryer drum with the other. Pull the drum out of the front of the dryer.
