Apple iPhone 3G Logo
Posted on Jan 30, 2010
Menu bar at bottom of screen does not repond during normal use ie unable access menu to make call etc but works when i use the slider to unlock the phone when turning it on . what is the problem and how can i fix it?
jacobcheatha
Level 1:
New Friend:
  • Contributor 19 Answers
  • Posted on Jan 30, 2010
jacobcheatha
Contributor
Level 1:
New Friend:
Answers
19
Questions
0
Helped
9496
Points
49
Sometimes its just running a little slow... try hard reseting it. hold the power button, and the home button at the same time for about 10 seconds. :) then power it back up!
How do you fix the sound
Assuming youve checked every volume slider there is (the one in whatever program your using, the one on the bottom right corner of the screen by the clock, and the master volume.....
Thab go to your start button on the bottom left of the screen (where you normally access all your programs), there should be a little "search bar" on the bottom of that list. Type on "device manager", scroll down the list and locate your speakers, right click and than go to properties. First try "update driver", if that doesn't work than click "Uninstaller driver" and restart your computer. That should do it.
2answers
I need to restore my factory settings and reboot my samsung n150 notebook how do i do it please
Here are a few things you can do or try
Restart the computer. If you are already in Windows, you can do this from the Windows Start menu, go to Turn off computer and click Restart. As the computer restarts, watch for a progress bar at the bottom of the screen. press F8 about once every second. Immediately press F8 before the progress bar reaches the right side of the screen. From the Windows Start-up menu, highlight Safe Mode and press Enter. Wait for your desktop to appear, and then make the necessary repairs (for example, uninstall programs or devices). When the repairs are done, restart the computer, and allow it to boot normally.
Alternate:
From the Windows Start menu, click Run. In the Open field, type MSCONFIG and click Ok. On the BOOT.INI tab, check /SAFEBOOT.
Click Restart when prompted.
Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10 key,ie: Alt+F10, it will open the recovery console ,select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer)
or
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
click start all programs accessories scroll to system tools from there you should see a system restore click next a sytem date should open up select the date you want to restore your computer to or if you want a full factory restore or
Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10 key,ie: Alt+F10, it will open the recovery console ,select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer) or
Hope this helps don't forget to vote
2answers
While trying to change settings on my computer I lost the Browser bar ie. file, edit, bookmark, icon for home forward and back feature, address bar
Most probably you pressed the F11 key in the upper key row on your keyboard, and it entered "full screen" mode.
Press F11 to exit full screen mode, this should do the trick.
If this is not the case, please come back and write a comment to that effect, we'll try to assist you further.
Good luck :)
3helpful
Black Bars each side of my new monitor wide screen
Right Click on an open spot on your desktop.
If your Operating System is Windows XP, choose Properties from the menu box that pops up when you right click.
A new window will open up. Click the Settings tab at the top right.
On this menu you should see a slider bar near the bottom left under "Screen Resolution". Left Click and hold the mouse button on the grey button and move it on the slider bar over to the right one spot. Then click the Apply button on the bottom right of the box. The screen may flicker for a second and your desktop will change size. If the screen covers the whole monitor and the black bars are gone, that may be the correct resolution. Click OK on the box that has a timer and is asking if you want to keep the screen that size. If the screen does not look correct, click No and you may need to slide the button one more spot over and try the next resolution and Apply until it looks correct.
Under the slider bar as you move it over a line at a time will be 2 numbers like this 1024 X 800, and when you move the bar over the numbers will change. I believe the optimal resolution setting numbers for the 20" monitor you have should be 1680 X 1050 for the widescreen. You may want to try that setting. If it looks too small, try sliding the bar to the left and try each resolution setting.
Here's a screetshot of what the Box with the slider bar looks like: http://technophobik.co.uk/vxp_control_panel/f007_settings.asp
If you have Windows Vista, (it is similiar to XP):
Click the Start Button and click Control Panel in the Start Menu
Click Appearance and Personalization in the new window that opens up.
Click Personalization, then click Display Settings at the bottom
A new box will pop up with the grey button on a slider bar near the bottom left under "Resolution" Slide the button to the right to the next line one spot over on the slider bar and then click the Apply button. The screen may flicker and change the size of your desktop. Click OK if the screen looks correct or click No if it doesn't look correct and try sliding the button over one more line.
Poor photo copy when printing 4x6 glossy in cassette tray.
Set the Ink Intensity (Windows) The Intensity setting controls the amount of ink placed on the paper. The higher the intensity the darker (more ink) the printed image will be. If the Intensity setting is set too high, the printed page may become too wet and curl or streak. Follow the instructions below to adjust the ink intensity settings.
  1. Access the printing preferences by opening the printer Preferences / Properties.
    For Windows Vista
    • Click / Select 'Start' from the bottom left of the Windows screen, 'Control Panel', 'Hardware and Sound', and then click on 'Printers'. Note: If you are in 'Classic' view, Click 'Printers' directly from the 'Control Panel'.
    • Click your right mouse button on the listing for your printer, and then select 'Properties' from the menu that appears.
    For Windows XP Home Edition
    • Click / Select 'Start' from the bottom left of the Windows screen, 'Control Panel,' 'Printers and Other Hardware,' and 'Printers and Faxes.'
    For Windows XP Professional Edition
    • Click 'Start' from the bottom left of the Windows screen, and 'Printers and Faxes.'
    For Windows 2000/Me/98
    • Click / Select 'Start' from the bottom left of the Windows screen, and 'Settings,' then 'Printers.'
  2. On the Main tab, select 'Manual' for 'Color Adjustment', and then click 'Set'.
3.Use the slider bar to adjust the 'Intensity'.
Note: Move the slider bar right to darken the image, and move the slider bar left to lighten the image.
Click 'OK' to complete the setup.
I hope it helps!!!
E720 cell - 'calls from this No. are barred'
Re: above question - Samsung E720 cell phone -  I am still getting same message when trying to make calls  :-  'all calls from this number are barred'    -   How do I turn it off or unlock this call barring. . I recently bought the phone and dont have any codes etc.  All the headings in the menu under 'Network Services' are in grey lettering instead of black , ie they are unaccessible,  ie 'call barring' 'call waiting' 'network selection' etc etc. phone was working before , so it must be something straightforward right?   Ian.
Samsung E720 Cell phone - 'Calls from this number are barred'
hi i hope u will fine .actually i have unlock my mobile samsumg sgh-e720 but i dont no who it is activate. plz send me puk coad of sgh-e720
thanks
Airplane Mode
My phone once resisted the bottom "unlock" slider for about 10 seconds. I think I just waited and tried again and it worked. If that doesn't work for you, run the battery down all the way.
Besides, once the iPhone boots up, it should go straight to the home screen, right? Not to the "locked" screen with the slider and wallpaper.
Top Apple Cell Phones Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Paul Bade
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
