Canon PIXMA MP210 Photo All-In-One Printer Logo
Posted on Jan 30, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When printing from the internet, even though all of the pages show in the print review, only the first page will print. The remaining pages go through the printer, but come out blank
Anonymous
Level 3:
  • Canon Master 2,517 Answers
  • Posted on Jan 30, 2010
Anonymous
Canon Master
Level 3:
Answers
2517
Questions
Helped
483656
Points
8373
Reaming page not active becouse net connection not recognized. print step by step, i meam page by page.
Cannon ir2022n printing blank page how to solve problem
Normally, the machine is set by a specific IP address initially. People run connect the machine though other internet connection in that case print shows blank page.
Just connect your machine with the IP address you did initially. And then try to print.
Otherwise,
Click the following link for online support
https://www.usa.canon.com/internet/portal/us/home/support/details/copiers-mfps-fax-machines/support-multifunction/imagerunner-2022
How to reset counter workcentre 6505dn?
Try this link:
Read the Billing Meter The total number of printed pages can be reviewed at the Printer Control Panel, on the Configuration Page, and in CentreWare Internet Services (CWIS).
Three meters are available:
  • Total Impressions
  • Color Impressions
  • Black Impressions
The billing meter counts the number of pages that were printed properly.
  • 1-sided prints, including N-up, are counted as one impression.
  • 2-sided prints, including N-up, are counted as two.
    NOTE: During 2-sided printing, if an error occurs after one side is printed properly, it is counted as one.
  • Color documents converted using an ICC profile on applications with the Color (Auto) setting can print in color, even if displayed in black and white. The data prints in color even if it seems to be black and white data on the Display Screen. In that case, the number of Color Impressions is increased.
    NOTE: Grayscale images printed with the composite black setting count as color pages because color consumables are used. Composite black is the default setting on most printers.
  • When printing automatic 2-sided printing, a blank page can be inserted automatically depending on the settings in the application. In this case, the blank page is counted as one page.
View the Billing Meters:
IMPORTANT: The Bill Meters track the total number of pages printed for the life of the printer; it cannot be reset.
To view the total number of pages printed:
  1. Press the [System] button on the Control Panel.
  2. Press the [Up] or [Down] arrow button until "Billing Meters" is selected, and then press the [OK] button. The Print Volume Report will be printed.
  3. Press the [Down] arrow button to scroll to the required meter. The number of printed pages is displayed below the name.
  4. Press the [Return] button to exit the Billing Meters menu.
http://wss.support.xerox.com/GTConnect/UnifiedAcceptor/AddWebFramework.Main/site/XeroxProductSupport/product/product_wc6505/lang/en-US/region/region_US/source/DND/Xlang/en_US/Xcntry/USA/prodID/WC6505/KBlang/en/#!view-content/ViewContent/View/contentId/x_6130_en-O8884
The page prints to a small version in top left hand corner. everything is set to A4. Have tried all settings Have tried paper feed from back and front. Unable to get it to print a full size A4 page even...
Make sure on the Page Setup tab that the Page Layout says 'Normal-size' and not 'Poster' (poster tries to place four documents on a single printed sheet). If this is not the problem, try uninstalling and reinstalling the printer driver.
When printing from internet all I get is the HTML background files and not the page I desire. Printer does fine from a document from the PC, just not the internet
nanapop56
In regards to printing from the Internet alot of it has to do with how the web page is coded. Even though the page may fit on your screen there may be page breaks and formating that will effect the over all content that actually get printed.
So there is 2 things you can do:
The first step in ether option is to highlight the info you want to print. Then do not click on the quick print icon in the tool bar but select File then Print. This will open the prin properties then you can select the option to print selection which will print the part that you selected.
Now if you still have trouble printing then next thing is while you selection is still highlighted is to copy the info and paste it into a document. This way you will see all the formating and can clean it up into an standard page size before you print it.
Hope this helps
Issken
2helpful
2answers
We have a spooling problem. The sharp mx-2300n just says "ripping" and 20% complete but won't move from there and print anything. Can cancel print job from Mac but won't stop anything at the printer end....
Go into the Job review mode and highlight the pending print job (note: it may be stuck in processing). You should then get the option to delete the job.
Make sure that the pending print job is also cleared from the network print queue. They can sit in the queue and be persistent on processing, even after you've cleared the copier. Clear the queue prior to deleting the job on the copier.
If this doesn't, disconnect the copier from your network and try the above steps again, then reboot the copier and reconnect it to your network.
If you're trying to print out Adobe-based web pages from the internet, this may be what's causing your copier to jam up. There's known coding anomalies with Adobe-embedded documents on web pages. Trying to directly print from the web page can stall or lock up the print process.
When i print a document, part of the print will be perfect, a couple of sentences, and then several sentences you cannot read at all, its too light or part of the letters are missing - for instance on an...
Follow the steps below to perform basic print quality troubleshooting.
1. Check your paper and verify that the all-in-one has clean, white, inkjet-rated or multipurpose paper in it. In many cases copier grade papers or paper specifically for Laser printers should NOT be used. These papers are frequently coated and are not intended for dye-based inks. The paper container should also have a brightness and weight listed on it. Generally speaking, the brighter and heavier the paper, the better the printout will look. HP recommends papers with at least 90 brightness and 75 g/m2 (20 pound) ratings.
2. Verify that the all-in-one is on a firm surface that fully supports its weight and does not move as the all-in-one prints. If the all-in-one is placed on a desk or other surface that is free to move or shake as the all-in-one prints, the printout will not look as good as it should.
3. Refilled or remanufactured print cartridges will often produce inferior results. HP will not support any print problems that result from the use of remanufactured and refilled print cartridges since their quality is not in HP's control. If you are using refilled or remanufactured print cartridges, replace them with a new HP print cartridge.
4. Print a self-test page from the all-in-one to verify that the all-in-one is working correctly. If the self-test prints correctly, go to Step 3. If the page does not print correctly, verify that the ink cartridges have ink in them. Then, unplug the power cord from the all-in-one, wait five seconds, and plug it back in. Contact HP for assistance if a self-test page still will not print. To print a self-test page, follow the step below:
5. Press SETUP (or MENU ) until " Print Report " displays, then press ENTER .
6. Examine the self-test page printed by your all-in-one.
i. If the colors are correct and the text is sharp and clear on the self-test page, the problem is not the all-in-one or the print cartridges. The problem is the print settings, the file being printed, or the program you are printing from. Continue to step 7 below.
ii. If the colors on the demo page are not correct or are missing, review HP document Printed Pages Are Missing One or More Colors but No Error Message Appears (buu02176) (in English).
iii.If the printout is not sharp or clear, skip the remaining steps in this section and review the remaining information in this document.
7. Try printing the document again but try changing the print settings by following these steps:
1. Within the application you are trying to print from, click File and then click Print . This will bring up the print screen.
2. Verify that the correct printer is selected and then click Properties .
3. On the Quality tab, verify that the correct paper type is selected, and then change the Print Quality setting to Best . Verify the settings on the remaining tabs are correct and then click OK .
4. Print the file you were trying to print again.
i. If the problem is corrected, the problem was the print settings. There is no need to continue troubleshooting.
ii.If the problem still exists, try printing on different paper.
8. Print a different file or image. If you have a file that printed well in the past, try printing that file. Low quality originals will not print very well. Screen captures and images from the internet are often at around 75 dpi. These images are at too low of a resolution to print well. If the self-test page looks good but your image does not, even after changing the print settings, the problem may be the original file. Cheers!!
Fading cartridge problems
That printer is pretty old. Are you selecting "Best" quality when you print or is it possible that some documents are being printed in Quick Print mode (which puts less ink on the page)? If you're doing the same thing on each print job but the print quality changes, there's definitely a problem. If you're printing from web pages, the print quality may be a factor of the design of the pages. If you print two pages of a multi-page document and quality declines, you should be able to get help through Lexmark's technical support.
HL-2070N will not properly print
My guess is the problem is with Firefox trying to print the page and not the printer. Try to go to File > Print Preview and see if it looks normal there. If not, I have 3 suggestions:
  1. Try to change the "Page Options" or "Scale" under the Print Preview
  2. Try to install and use the Firefox Add-On "IE Tab". This gives you the choice to display the page with Internet Explorer, while still using Firefox. You can turn on IE Tab, and then try to print. https://addons.mozilla.org/en-US/firefox/addon/1419
  3. Upgrade to Firefox 3.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jerry_779afc81ec0a7712
Can't print landscape?
Make sure the correct printer driver is installed.Check your user guide.Read the information below.
Printer Settings
You can use the printer properties window, which allows you to
access all of the printer options you need when using your
printer. When the printer properties are displayed, you can
review and change the settings needed for your print job.
Your printer properties window may differ, depending on your
operating system. This Software User’s Guide shows the
Properties window for Windows 98.
Your printer driver Properties window that appears in this User’s
Guide may differ depending on the printer in use.
If you access printer properties through the Printers folder, you
can view additional Windows-based tabs (refer to your
Windows User’s Guide) and the Printer tab (see “Printer Tab” on
page 10).
NOTES:
• Most Windows applications will override settings you specify
in the printer driver. Change all print settings available in the
software application first, and change any remaining settings
using the printer driver.
• The settings you change remain in effect only while you are
using the current program. To make your changes
permanent, make them in the Printers folder.
• The following procedure is for Windows XP. For other
Windows OS, refer to the corresponding Windows User's
Guide or online help.
1. Click the Windows Start button.
2. Select Printers and Faxes.
3. Select your printer driver icon.
4. Right-click on the printer driver icon and select
Printing Preferences.
5. Change the settings on each tab, click OK.
Layout Tab
The Layout tab provides options to adjust how the document
appears on the printed page. The Layout Options includes
Multiple Pages per Side and Poster. See “Printing a
Document” on page 6 for more information on accessing printer
properties.
Orientation
Orientation allows you to select the direction in which
information is printed on a page.
• Portrait prints across the width of the page, letter style.
• Landscape prints across the length of the page, spreadsheet
style.
• Rotate allows you to rotate the page the selected degrees.
Layout Options
Layout Options allows you to select advanced printing options.
You can choose Multiple Pages per Side and Poster.
• For details, see “Printing Multiple Pages on One Sheet of Paper
(N-Up Printing)” on page 12.
• For details, see “Printing Posters” on page 13
Page count unreasonable
Re you using genuine HP NEW cartridges? If not, you must make sure that whoever has re manufactured the ones you are using has replaced the chip on the cartridge. This tells the machine how many copies are on the cartridge.
old marine
old marine
ZJ Limited
ZJ Limited
