Posted on Jan 30, 2010
Technics tuner amplifier sa-eh750 makes crunching noise and f61 comes up on desplay
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jun 01, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1515
Points
5
I want to change the language on technics hi fi sa/eh750 to english
What does F61 mean on a technics SA-EH770 hifi system
https://technoanswers.blogspot.com/2011/08/error-code-f61-on-technics-tuner.html
Sa dv 170 technics amplifier i have an error f 61 please help ty james
Immediate the machine switch off then you will see the F61
What errore code f61 means on technics sa eh750 amplificator?
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it '*****'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
I need a manual for a SA EH750 stereo system
You can download the service manual from here:
http://elektrotanya.com/technics_sa-eh750.pdf/download.html
Please wait until the page is appeared fully then click on this place:
Get Manual
Not logged in
Only 2 downloads
allowed a day
and the downloading will begin.
Thanks.
gylacz
2answers
2answers
F61
i had the same problem with the error code f61.There are 2 fans,1 external and 1 internal and were both working but were very clogged up with dust thus working harder.Try cleaning them both it worked for me on the SA-HT 990 model
Cuts out
Check your speakers. your speaker may be defective
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Kolbrun...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
