I have china mobile n95, my china mobile is not detected by my pc why?
Go at link below and select Nokia PC suite version according to your Operating System of your PC.
http://europe.nokia.com/A4144905
Well you first need to configure your mobile to get detected
For this enter Engineering Mode by pressing
*#3646633#
In Engineer Mode select Device Menu
Select Set UART Menu
Select UART Power and set all UART to ON
Then select UART Setting Menu
in UART Setting Menu set TST Config to None
set PS Config to UART 2
again in Device menu select SWDBG menu
in SWDBG menu select DSP L1
This should enable your mobile
Please do not change any other settings
if you do not know about them
this may malfunction your mobile
After Done these steps , There is no change in mobile. Same problem is repeated,
Mobile is charging but it is not detecting while I inserted the USB into computer
please help me then there is no SWDBG option in Device menu my mobil is china E71++ my email is [email protected]
You need to install the software for that particular mobile so that your system detects the mobile. For eg. to work on a nokia mobile with your system you need to install the nokia pcsuite software...similarly u need to install the software for your china mobile
then there is no SWDBG option in Device menu for my E71++ please help me my email is " [email protected] thank you
Hi NobleWorld,
I have done all the steps above you specified
"For this enter Engineering Mode by pressing
*#3646633#
set PS Config to UART 2"
My Mobile's(GFive T33+) device menu list has
1. LCD
2. GPIO
3. PWM
4. EINT
5. ADC
6. Set default level
7. Set UART
8. Sleep mode
9. DCM mode
10. PMIC 6318
11. FM Radio
12. RTC XOSC (WO)
Please help me, what can i do?
my mail is : devasena[dot]it[at]gmail[dot]com
Thanks
my mobile phone cant detect by my pc
i have a 6300 made in china double sim clone mobile........when i connect it to my pc on windows xp....it does not detect it..........nothing happens at all......it starts chargin but the connection via usb is not detected
i have a 6300 double sim clone chinese mobile....when i connect it to my pc nothing happens......it starts charging but the connection via usb is not detected at all
my cect89 model china mobile was initially detected by my pc...bt few days back wen i tried connecting it ,its not being detected...but the mobile starts getting charged
my phone has being going on charging but not showing as connected......
