Question about Sharp AR-5316 Advanced Digital Imager Copier
When there is low voltage and the stablizer cannot power the copier, the error code 4H appears and copying cannot be done. what can be done about this? is there a code that can be used to correct this?
WHEN THE SHARP AR-5316 PHOTOCOPIER IS SWITCHED ON THE ERROR CODE 4H APPEARSAND THE MACHINE CANNOT BE OPERATED. IHAVE TRIED THE SOLUTION SUGGESTED JUNE THIS YEAR BUT IT DID NOT WORK. WHAT CAN I DO TO GET THE MACHINE TO WORK? IT IS VERY URGENT.
Posted on Jan 07, 2009
Error code F2 on sharp ar 5316
Posted on Mar 22, 2010
I have a copier Machine Sharp AR-5127, the error is F2-02, is there any code to correct this?
Posted on Mar 29, 2008
This should do it
NOTE: Some Status codes will not clear even though the problem has been fixed. Status codes that will not clear must be manually reset using the 'Fault Reset 14 Procedure'.
Posted on Feb 18, 2008
I have sharp AR-5316 error code is showing (d)
Posted on Jul 29, 2013
My Sharp AR6050 showed error code C1-00. How to reset it? Help me..
Thank alots
Posted on Sep 10, 2008
All you need to reset this error is in the service manual for this equipment:
http://www.tradebit.com/filedetail.php/185184978-sharp-ar-5316ar-5320-service-manual
Posted on Aug 04, 2012
Engr. KhanAqa Safi solution worked pretty good. What he dint include is, u av 2 b fast while doing it.
Posted on Jun 04, 2012
Its very urgent, when i start the sharp ar5316 machine . its does not start after few minuets also,in display in middle of top thr is round cirle symbol thats keep on blinking until it goes its does not start... but tis never goes after i restart several times also, after 1 hours if i switch on the machines its starts or sometimes it does not plz help me what is this error called,i think its look like termistor / heater symbol .. how to fix it. its a major problem i got .
Posted on Feb 07, 2016
Abnormal temparetur apply
# interput C interput =14= copy batton/ start batton
=15=
Posted on Nov 02, 2014
Jul 20, 2012 | Computers & Internet
Code Error name/description
E000 fixing overheating
E001 fixing assembly overheating
E002 fixing assembly low temperature
E003 post-standby fixing low temperature
E007 fixing film rotation error
E010 main motor rotation error
E014 fixing motor rotation error
E019 waste toner case full, waste toner case full sensor error
E020 toner clogging between sub hopper and developing assembly
E024 developing assembly connector disconnection
E025 hopper motor, bottle motor error
E032 NE controller counter error
E064 power supply voltage error (high-voltage)
E100 BD interval error
E110 scanner motor error
E191 communication error for high voltage power supply
E202 CIS home position detection error
E225 CIS light intensity error
E227 reader unit power supply error
E248 backup memory error
E261 zero-cross signal error
E315 image data error
E400 feeder communication error
Mar 03, 2011 | Canon ImageRUNNER 3570 Copier/Printer
Aug 19, 2010 | Sharp AR-M160 Black and White Copier
Aug 05, 2010 | Sharp AR-5316 Advanced Digital Imager...
Oct 15, 2009 | Sharp AL 1631 Copier
Oct 09, 2009 | Sharp AR-5316 Advanced Digital Imager...
Oct 01, 2009 | Sharp AR-5316 Advanced Digital Imager...
Jan 28, 2009 | Sharp AR-5316 Advanced Digital Imager...
Sep 10, 2008 | Sharp AR-5316 Advanced Digital Imager...
Apr 15, 2008 | Sharp AR-5316 Advanced Digital Imager...
Jul 08, 2014 | Sharp AR-5316 Advanced Digital Imager...
9,802 people viewed this question
copy coming with with some black background
discovered that any time the copier is powered, the 4H just keeps appearing.it is a sharp 5316.
yes the same problem with my copier also that it shows to use h4 but not copying.
when there is low voltage and the stablizer cannot power the copier, the error code 4H appears and copying cannot be done. what can be done about this? is there a code that can be used to correct this?
My Sharp copier AR 5316 has the Error code H4 .it was happened when the voltage was low.
I am Engineer Khanaqa Safi .My Copier Sharp AR 5316 has the error code H4. It was happened when th valtage was falling down and up.I tried to fix it by pressing C and Image quality button for 4 second but I couldent fix it .
Hello Dear friends!
I am Engineer KhanAqa Safi from Afghanistan.I have 10 Sharp AR5316 copiers .My Copier had the ERROR Code H4. I have Found how to solve this problem. I have the following recommendations for you :
1- Press Interrupt key once
2- Press # Key once
3- Again Press Interrupt Key once
4- Then press C (Clear ) Key once
5- Again press Interrupt key once
Machine goes to be like off(Don't off Your Machine)
6- Press 1 key and 4 (14)
7-Press Print key ( Green Key on the right)
Now your Machine is fixed
???¯? ?¬???§?² ?´?§?± ?£? ?§?± ??????? ???? ????? ???? ?§???¬???§?²
When the Sharp AR-5316 photocopier machine is switched on the error code 4H appears and the machine does not operate. I have tried the solution given somebody from Afghanistan and it does not work.
What can I do to get the machine to work. It is urgent
When Sharp AR-5316 is switched on error code 4H appears and the machine cannot be operate. Recommendation by Khanaqa posted on June 03,2008 has been tried bit it did not work. What can I do to get the machine to operate normally. It is very urgent
youpele from Port Harcourt Nigeria.
I had error 4H on Sharp AR-5316
I have the copier machine Sharp AR-5127 ,the error code U240 appears and coping cannot be done.What can be done about this ? is there a code that can be used to correct this?
pls you help me.
thank you very much.
Its actually H4.. hold and press copy button to see the full code error. Most common error in H4 is H4-00 or 01... Use AVR... and insert the trouble cancellation code...
If all the procedures mentioned by Engineer Khanaqa Safi did not work.. You must change the heater lamp, thermostat and the thermistor that you can see in the Fusing Unit...
