The mount for my quantaray lens is broken ,where can I get a new mount ( for nikon AF SLR)
SOURCE: used on a Minolta Maxxum 800 si
Hello
The Minolta AF lens will fit and work on most of the Minolta AF bodies (it will depend on exactly what lens it is as to the compatibility), you will also find that it will fit and work with the new range of Sony
digital SLR camera bodies.
The Quantaray lenses are a little bit more difficult as Quantaray make lenses for several different types of camera body, it should mention on the lens what make the lens mount is for. If you post further information about the lenses it might help.
SOURCE: cameras compatible with Quantaray AF 70-300mm lens
Depending on how new your Minolta SLR film camera was, the lens may or may not work on a Minolta Digital SLR. In many cases, a lens with the correct mount (in this case, a Minolta mount) can be used on the same brand of camera in the digital format.
One thing you should know is that DSLR sensors are, generally speaking, smaller than the size of a 35mm film negative. Long story short, that means that your lens will have a magnification factor on the DSLR. Usually, it is in the range of 150%, so a 70-300 lens from a film camera would cover 105 to 450 on a Digital SLR.
To be sure about the mount, you'll need to seek advice specific to Minoltas -- probably best to take your lens to a local camera shop and see for sure if it fits and what features will work (aperature, auto-focus, etc) and which won't work on the DSLR.
SOURCE: Will my quantaray tech-10 NF AF zoom lens (for me
Yes, with caveats. The autofocus won't work on D40/D60/D3000/D5000. The metering may not work in all modes on all cameras. Since you didn't specify which camera, I can't give you a better answer than that.
I have 30-year-old Nikon lenses working fine on my D90, but without metering. And the old lenses date before the invention of autofocus.
SOURCE: Can the quantaray for Nikon
Yes, assuming we're discussing SLR cameras. It can also be used with most Nikon film SLRs.
For Nikon AF and manual focus SLRs. The compatible T Mount System makes it possible to use most any single lens reflex camera in combination with various front camera attachments such as telescopes, mirror lenses and slide duplicators. The T Mount is a metal connector that screws onto the compatible front attachment and allows this combination to be coupled to the SLR camera lens mount.
