Question about iLO 3200 32 in. LCD Television
Envision remote codes
L32W761 hdtv need remote control coed
  • 8 more comments
  • mantome Feb 18, 2008
    Envision L32W761 HDTV TRYING TO PROGRAM MY DISH REMOTE - NEED CODE FOR ENVISION REMOTE
  • Anonymous Feb 27, 2008
    I have the same problem trying to program my remote on my newly purchased envision l32w761Can some one help me.
    thanks,
    David
    dalaniz48@hotmail.com
  • musicalmom Mar 16, 2008
    I need a code for my Dish network remote to work with my 32" Envision L32W761 TV.
  • MaRobert Apr 03, 2008
    Cant program Dish Network V 612 HD-DVR remote to control volume/mute on my new Envision L32W671. It will control on-off. I have tried the 6 codes on page 112 of the Dish users guide. Thanks.
  • frazzini May 02, 2008
    Same problem here as well. I have tried to scan for the code but with no luck. I can only get the power to to work with no volume controls. Dish network has only the same six codes that I already have.
    John
  • kateeo May 21, 2008
    i cannot get amy universal remote to work with 32'envision - only power
    no volume, etc
  • widmeyerl Sep 10, 2008
    I have a Envision L37W698 I cannot find a remote control code for my Direct TV remote. I have tried all the codes I can find
  • Anonymous Jan 24, 2009
    I have an envision digital tv, I was using the remote one day 2419200154P and all of a sudden it quit. Do not know how to fix this. I put in new batteries
  • jdantinne Jan 28, 2009
    I have a envision l42h861 and am trying to find the 3 digit code to program a pioneer remote, can anyone help?
  • wilkiek May 07, 2009
    I can not program the Comcast remote to my Envision TV. I've tried all the codes recommended by the apprentices on this site and they don't work. Any more suggestions??
    New Friend:
AHA!!! If you're having problems getting your envision flat screen to recognize a DISH NETWORK REMOTE CONTROL... the 3 digit code is 772.
It took me about three hours to figure it out and the customer support line at ENVISION is absolutely worthless. Next time I'll buy a SONY.
Posted on Jan 12, 2010
I could not program the Comcast remote to my Envision TV so I went looking and mixed a 5 digit code with the 4 digit code listed in the book. The end result was 10030, and it worked!
HIT TV on remote
HOLD set up button until the TV button blinks 2x's
HIT 10030 and TV button will blink
HIT set up
HIT power...TV will then shut off
Good Luck!
Posted on Oct 26, 2008
Try
10813
11365
10032
10039
10019
Posted on Mar 31, 2008
  • mkreck Feb 04, 2012
    All of these codes do not work my mute button. Volume yes. Mute no.
    New Friend:
Answer is 4 digit code 0030 for comcast remote. follow their instructions and code 0030. the true master of total disaster your welcome
Posted on Dec 30, 2009
Dish remote codes are only 3 digits
Posted on Jul 28, 2008
    New Friend:
If you use the code 10030 for comcast HD remote it will control sound and power
Posted on Nov 12, 2010
6ya staff
SOURCE:
I've lost the remote control for my AOC Envision L32W761. How can I change the menu and input source options using the front panel controls? I'm able to access the menu screen but can't figure out how to...
Try navigating the screen using the volume and channel controls. If you still can't get to the left side of the screen then try press the menu button again while on the menu screen to see if it'll navigate you there.
Hope this helps :)
Apr 20, 2014 | Envision L32W761 32 in. LCD TV
I have a 32" AOC Envision L32w761 LCD hdtv with no
There are only two things that can cause this problem -inverter and T-con. Since you have already replaced the inverter, it can be nothing other than the T-CON or LCD controller. Replacing the same should resolve the problem. On a side note the inverter/T-Con problem can be isolated easily. The purpose of the inverter is only to light up the backlight of the panel. So when it fails you will still have a faint picture that can be seen if you flash a flashlight on the screen. If you would like me to find you the replacement T-con let me know the part number and I will get you the link to the part.
Sep 07, 2011 | Envision L32W761 32 in. LCD TV
What is the comcast remote code for aoc envision tv L32w761
Directly from Comcast.com
AOC 3,010,017,025,044
Hope this helps.
Aug 27, 2011 | AOC Envision L27W461 27 in. HDTV LCD...
I cannot get my dish network remote to work the volume for the envision model L32w761. What codes do I need to use?
Hello, I hope that this has been resolved for you, but if not, or if you still have some questions, follow the link provided below, and that remote will be working in no time!!! The link will show you how to run a power scan, so that you can get that remote programmed.
http://www.dishnetwork.com/SupportSection/power-scan-instructions
Becki Barned
DISH Network Customer Service
Nov 15, 2010 | Envision L32W761 32 in. LCD TV
L32W761 32 in. LCD TV: my channel changer stopped working only the power ...
Channel changer from the remote? or from the TV? if it is from the remote, that's an easy fix, take off the batteries open the back of the remote, clean the circute board the one that is painted green, clean the remote contact pads as well the one that has a black dot like thingy with cotton balls slightly damp in rubbing alcohol, let it dry put it back together and replace with a new battery.
May 18, 2010 | Envision L32W761 32 in. LCD TV
Screen Size on my Envision L32W761 TV is cutting off the picture.
Look on the remote for a button labelled ASPECT,P SIZE, ZOOM or FORMAT. Press it until picture is desired size.
Oct 04, 2009 | Envision L32W761 32 in. LCD TV
iLO 3200 32 in. LCD Television Logo
7,796 people viewed this question
Top iLO Televison & Video Experts
Ekse
Jerry Greenberg
Jerry Greenberg
matt martin
matt martin
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
