Samsung PL 70  SL720 Digital Camera Logo
Posted on Feb 01, 2010
Samsung pl50 camera - lense wont go back in and wont turn on
My samsung pl50 camera was working fine and hour ago, then i turned it off and tried to turn it on again but it made a bleeping sound and just kept turning off so i pressed the playback button then it came up with one of my pictures for a few seconds then made the bleeping sound again and turned off but the lense still remains out
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jul 20, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1193
Points
The problem with mine was that the lens motor was somehow stuck. I gently pulled the lens out as I turned the camera on. It went back to normal afterward. Hope this helps
  • poei101 May 16, 2011
    Tnx friend... it helps,, great. i pulled gently outward twist a bit .. and its ok..
Anonymous
Level 1:
New Friend:
  • Posted on Dec 15, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1193
Points
I have a Samsung PL120 I have had it for about a year now. I tried using it but now it wont turn on. I charge it for at least one hour or more but yet it still wont turn on. I don't know what seems to be the problem if some one can help me please.
Anonymous
Level 1:
New Friend:
  • Posted on Apr 28, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1193
Points
I need help with this too! :(
1 Related Answer
Anonymous
  • 411 Answers
  • Posted on Mar 30, 2010
SOURCE: samsung PL 50 lens stuck half way
mechnism of the lens is deffective,get it serviced.
1helpful
My samsung PL50 camera: i havent used my camera in a while but i bought a new charger, it is full charged and i can browse the pictures, but as soon as i press the on button the lense trys to move but will...
OK, the lens assembly has failed causing a shutdown error. So, technically, the camera is trash because it would WAY more expensive to fix that one than to just buy a new one. NOW, read carefully. When you power on the camera, watch when the lens tries to come out. You'll notice that the shutter on the lens opens first then it pokes out a bit then goes back in and shuts down. If you time it right, you can slip your fingernail under where the shutter is and "assist" the lens out more. dont pull too hard because you'll rip the fron of the lens assembly off. but once it is able to go past this point, 9 times out of 10, it fixes the problem entirely and the camera works just fine after that.
7helpful
My samsung pl50 won't turn on it just bleeps at me when i try and the shutter is stuck out. it was working fine when i was taking pics of my sister then it just shut down n won't turn back on
I've sent back 2 phones with this exact problem. Came on here and found the solution on the blog from another camera. It works! Here it is:
Figured it out....the zoom lense, while in the open position, was a little out of line, thus preventing the camera from retracting it. After gently re-aligning the lense, it retracted properly and the camera resumed normal functioning.
So basically, wiggle the lens every so slightly then try the power button again. Hope it works for you!
1helpful
Samsung PL 50 lens stuck half way
12helpful
Samsung PL50 camera wont unlock memory card
There is a little sliding switch on the side of the memory card. Make sure it is not on lock.
Mar 01, 2010 • Cell Phones
Samsung pl50 lense jammed?
Hi
Thanks for using FixYa. Please check the battery is fully charged.
If you are able to access the Menu, please select Initialize under Settings and Main Settings 1 Menu and press OK. If still the issue persists, perform the power reset by removing the Battery and pressing the power button continuously for one minute. Then, leave the power button and reinsert the Battery.
To reset the Digital Camera by using a RESET button follow these steps---
  1. Locate the RESET button on the camera.
  2. Use a pointed object (like a ballpoint pen) to press and hold the RESET button for 2-3 seconds.
  3. After 2-3 seconds has elapsed, release the RESET button.
To perform a manual power reset follows these steps---
  1. Turn off the camera.
  2. Remove the battery pack.
  3. Remove the button-sized lithium battery.
  4. Allow the camera to remain without power for 30 seconds.
  5. Reinsert the button-sized lithium battery.
  6. Reinsert the battery pack.
  7. Turn on the camera.
If still the issue persists then it means that the cabinet is opened or LCD cable is touched which is caused by connection defect or poor contact between connector and LCD cable due to the pressure by the rib in the front cabinet to the connector. If still its not resolved then as its a new one so you should use its warranty and get it replaced just to avoid future issues.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
3answers
Digital camera
I had the same problem. After I "tore" the camera apart, I put rubbing alcohol all around the lense where it goes in and out. I then used a high quality synthetic oil that is for Grandfather clocks and other mechanical clocks to oil it again. I then ran the lense in and out (by turning it on and off) quite a few times to help work the oil down into the gears. My camera seems to be working fine now.
Samsung Digimax D53; 5.0 megapixels
Mind did the same thing. Try taking out the memory card. If it works after that, you'll have to buy a new memory card.
2answers
Cameras lense open, camera off, when turned on it bleeps and turns itself off
i have exactly the same problem with exactly the same camera. It happened to me once before but by 'fiddling' with it, it seemed to catch back in place and turn on again. but this time it wont work. seems like a design fauly from samsung?
Top Samsung Cameras Experts
ZJ Limited
ZJ Limited
Are you a Samsung Camera Expert? Answer questions, earn points and help others
