LG WM-2277HW Front Load Washer Logo
Posted on Feb 01, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My washer won't drain! The OE message was on, I
My washer won't drain! The OE message was on, I cleaned the filter, re ran the load and it still won't drain.
Anonymous
Level 2:
New Friend:
  • Expert 129 Answers
  • Posted on Feb 02, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
129
Questions
0
Helped
24628
Points
221
Have you cleaned out the water pump and hose ? check drain hose for blockage, check pump wiring to make sure it has a good connection.120 volts to pump. pump or board bad.
1helpful
Water won't drain and it says oe
Hello & Welcome to FixYa
OE is a drain error and is displayed when the washer is unable to drain water. Please check the drain hose and drain pump filter for any clogs to clean the error. Please get back to me if you have any other questions.
Kevin
1helpful
2answers
Washer has water still in drum and OE on digital readout
Hi
Thanks for using FixYa. OE is a drain error, it flashes when the washer won’t drain within 10 minutes. TO resolve this issue you’ll have to check the drain pump filter for any clogs, also check the drain hose for any kinks and clean the drain pump filter. If still the issue is not resolved then you might have to replace the pump. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
6helpful
What does OE stand for on my washer
Hi
Thanks
Rylee
I have an error code "oe". in the past we have installed a new rotor, stator, wiring harness and control board. it was a load of towel, so i unloaded half and tried again. no luck. "oe"
Hi
Thanks
Rylee
Oe code, i need to clean the black hose on the bottom of the washer how do i do that. thanks
Hi
Thanks
Rylee
4helpful
2answers
"OE" message
OE is actually DE - Drain Error. Pop open the little door on the bottom left of your washer, and unscrew the cap on the little tube on the left. ***Water will drain out!***
Once the water is out, unscrew the bigger tube on the right. This holds your drain filter. It is likely clogged, so clean it out and reinstall the filter and cap from the small hose.
Hopefully this fixes it!
2helpful
I have an OE code on my WM1814CW LG Washer
OE code - Check for clogged drain filter on end of hose, bent or clogged dain hose. Make sure hose doesn't go too far down drain pipe.
Hope this helps
Bob
3helpful
MY LG WASHER WONT DRAIN, IT SAYS THE ERROR MESSAGE
OE is a drain error - Check there isn't a kink in your drain hose, ensure the filter is clean, the drain hose can become clogged with sludge, sometimes a hot wash with 1/2 a cup of vinegar will remove this sludge
4helpful
Message OE
OE : Drain Hose is Kinked or clogged or The Drain Filter is clogged - Clean and straighten the drain hose / clean the drain filter.
also do check for the pump blockage.
for more info on this check the following link
http://pastoralfarms.us/2008/04/21/lg-fl-washer-2277-oe-error/
Top LG Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
