SOURCE: just after basic programming for 8 in one
Rank:
0121 0222 0229 0235 0261
LG:
0404 0419 0383 0414 0296
Try the auto code search. Switch on the device > Select the device key to program > Hold the green "Set" button for 3 seconds > Press "OK" at "Setup" > press "OK" at "Code Se[t]" > Press the down arrow to highlight "Auto" > Press "OK" > Aim at the device > Hold the down arrow for 2 seconds > Press the "OK" button when the device powers off.
SOURCE: Cobolt 68cm (MCTV68A) TV purchased without remote.
If remote was made before tv and they used new codes for tv then it won't work even if it is the same brand.
SOURCE: universal remote codes for cobolt tv
0698 - It's about than 40 codes in if you are searching manually.
SOURCE: Antsig AP593 universal remote
Not sure if you've decided to throw your remote control away already or not. But try using the manual search code. Basically press "TV" (light blinks once), then press the "Up" channel button and the "up" volume button at the same time (light comes on permanently), then hold down "Power" whilst putting the remote RIGHT IN FRONT of the place where your tv receives signal (usually where you can see a light), and I mean right in front! Hold it down until your tv powers off. Then it should be configured and working. It took me about 1 minute or more for the TV to react and turn off. Then you can check if it turns on again and if the channels are working.
