Dell Vostro A860 Notebook Logo
Anonymous Posted on Feb 02, 2010
Dell Vostro A860 Touchpad Issue
Dell Vostro Notebook A860, Service Tag: 8XXQLH1
When using the Touchpad, the pointer on-screen regularly stops for a brief moment. I've reinstalled the Touchpad and Display drivers (running Vista Home Premium).
All attempts have failed to fix the problem, including running virus scan (McAfee) to check for hacker.
Any other suggestions?
Anonymous
Level 2:
Scholar:
  • Expert 129 Answers
  • Posted on Feb 28, 2010
Anonymous
Expert
Level 2:
Scholar:
Answers
129
Questions
0
Helped
77925
Points
362
HI
IT MAY BE DUE TO SOME PROBLEM IN THE DRIVER ..
BETTER TO DOWNLOAD A NEW VERSION OF TOUCH PAD DRIVER (INTERNET) FOR VISTA HOME PREMIUM 32/64 BIT
HOPE YOU BE SUCCESSFUL
Dell vostro a860 system or admin password needed
You can remove or change the Window's User or administrator's password. You need access to a computer with Internet access to download the Hiren's Boot CD and burn it onto a CD. Then insert this CD into the laptop/computer and boot up the laptop/computer with the Hiren's CD and follow the instructions. There are very useful utilities CD and it a Linux boot CD which contains quite a lot of Utility programs including a password removal program. Click on one of these links to download HIREN'S BOOTCD :- http://www.hirensbootcd.net/ http://67.20.82.163/
In my dellvostro a860 , rite side of the screen colours are spreaded,it it looks like shade,,whats the problem in that i m not getting please help me..........
It is the screen Inverter, or the LCD screen itself.
Screen Inverter: A small circuit board located behind the Display Bezel, and mounted towards the bottom of the LCD screen,
http://support.dell.com/support/edocs/systems/vosA860/en/sm/display.htm#wp1183775
The yellowish long object, at the bottom, is the screen Inverter.
Here is another look at it,
http://www.batterycenturys.com/dell-vostro-a860-inverter-p-185294.html
Dell Support > Vostro a860 Notebook PC > Service Manual,
http://support.dell.com/support/edocs/systems/vosA860/en/sm/index.htm
In the list clicking on -> Display, will get you to the first link above.
Need guidance in replacing the screen Inverter, post in a Comment.
(Just a basic guide using a Vostro 1014/1015 Notebook PC. Not yours, but good for basic guidance. This is replacing the LCD screen,
http://www.insidemylaptop.com/replace-lcd-screen-dell-vostro-1015-1014-laptop/
[ Primer:
An LCD screen cannot produce light by itself,
http://solutions.3m.com/wps/portal/3M/en_US/NA_Optical/Systems/BehindTheScenes/Optics101/
( Click on the small window with the monitor in it )
It needs an additional light source. A Backlight is the additional light source.
A Backlight can be a CCFL, (or more than one), or a series of LED's used as lights.
The Dell Vostro a860 Notebook PC uses one CCFL, for a Backlight, OR there are Vostro a860's that use LED lights.
(If you replace the LCD screen, make sure FIRST of what type of Backlighting it uses)
A CCFL is a Cold Cathode Fluorescent Lamp. Similar to Fluorescent lighting used in homes, and businesses, but on a MUCH smaller scale.
[Average thickness of a CCFL is 2mm. That is a little larger than 1/16th of an Inch.
Average length is almost as long, as the LCD screen is in height ]
A screen Inverter is used to convert the power from the laptop, for the Backlight, and LCD screen.
Most of the time the fault is the screen Inverter.
The Vostro a860 Notebook PC's, that uses LED's as a Backlight, MAY also use a screen Inverter.
Primer over.
For your problem it could be the screen Inverter, but I lean more towards the LCD screen itself, is the problem.
How to test a screen Inverter? Requires a very sensitive multimeter.
Read; Expensive,
http://www.fonerbooks.com/test.htm
For a layman who does not have access to a sensitive multimeter, the method is to just replace the screen Inverter, and see if it is the problem.
'Parts changing', I know, but if you do not have the proper equipment to test with?
Screen Inverter replaced, and problem still persists, replace the LCD screen,
http://www.laptopscreen.com/English/model/Dell/VOSTRO~A860/
For additional questions please post in a Comment.
Regards,
joecoolvette
2helpful
I have a dell vostro A860 laptop.not working to Touchpad. How to Fix Touchpad Not Working in Laptop
What you can initially do is to update the driver.
  1. Press on the windows key + R. A run box will appear.
  2. Type devmgmt.msc then click on ok. The device manage will appear.
  1. Click on the plus sign besides mice and other pointing devices.
  2. Right click on the item that will be pertaining to your touch pad.
  3. Choose update driver and let the internet work for you.
If this does not work, you will need to totally reinstall the driver.
  1. On the same screen (device manager) right click on the touch pad driver again, the choose uninstall.
  2. follow the prompts for uninstallation. You might wanna uninstall any mouse related drivers as well (these application can also cause conflicts thus causing your touch pad not to work)
  3. download the touch pad driver available from the link I provided below.
  4. follow the prompts for installation.
  5. restart
Dell Vostro Driver list (click here to view all available drivers for your portable system)
Dell Vostro Touch Pad Driver (click here to download the touch pad driver)
It this does not work, you will need to call Dell Technical Support to have the laptop serviced. That is if the portable still has warranty. If not, then you will need to buy a USB mouse as a replacement.
for additional information visit Dell support website: support.dell.com
I have a dell vostro a860 laptop.but it doesnt play audio.I have its audio dirver but it ask for mixer device.I dont know what to do? can you help me out.i am hoping for your reply.
You can download the drivers from Dell WEB site, thesupport download page. Make sure you select your model desktop or laptop,better still, type in the Service Tag number, it is printed on the label on thebottom of the laptop and on the back or sides of a desktop. (If the Service Taglabel is missing then go into the BIOS setting and on one of the BIOS pages,the Service Tag number will be displayed). This will open the page where thespecific drivers for your model computer are located. Also make sure you selectthe Windows XP or Vista version of the drivers for your Windows operatingsystem. Click on this link to download the drivers: - http://support.dell.com/support/downloads/index.aspx?c=us&l=en&s=gen
2helpful
3answers
My dell vostro a860 keeps over heating because i dropped and now it over heats because the cores get up to 93 degrees celsius
Due to the shock, your laptop may have broken and have displaced parts and the fan/ heat sink etc might not be working. Over heating can cause further damage. Hence, it is strongly recommended that you immediately seek professional assistance to avoid any permanent damage to the system
GoodLuck!
Dont forget to appreciate the solution if I could have been of any help!
CreativeTECH
1helpful
I have install window srvice pack 2 then I have a problem of all the driver ie vga, sound,usb,base systm and video controller.My lap top is Vastro A840 n series. kindly send me solution
you can download all the driver for your Dell vostro A860 notebook from here follow this link to download the drivers,
http://www.getpcmemory.com/drivers/dell-vostro-a860-download-dell-vostro-a860-notebook-windows-xp-drivers/
this will solve your laptop driver problem
Thank you for using Fixya.
Regards
Manish
Dell Laptop Model A840 Operating system-XP wifi is not working even internet with wire also not working
you need the following to resolve this issue, your service tag number its written under the laptop, after you have retrieved it , go www.dell.com, or http:// support.dell.com and folow the instructions
OHCI complaint ieee1394 host controller not recognising DV camcorder. ieee1394 device displays in device manager.problem in Dellk Vostroa840 laptop.
go to support.dell.com and click on drivers and downloads and enter in your service tag and update drivers like bios and mobile chipset.
Need compete drivers for win xp
You can go to this link. Look under the drivers section and plug in your service tag ID. Then select drivers and downloads for Windows XP.
1helpful
Connexant modem and audio drivers
You can download the drivers from Dell WEB site, the support download page. Make sure you select your model laptop, better still, type in the Service Tag number, it is printed on the label on the bottom of the laptop. This will open the page where the specific drivers for your model laptop are located. Also make sure you select the Windows XP version of the driver for the Windows XP operating system.
Click on this link :-
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
