HP PSC 1610 All-In-One InkJet Printer Logo
Posted on Feb 02, 2010
I upgraded my Mac mini to Snow Leopard OSX 10.6.2. Reloaded the printer software but the printer wont print. THe printer is connected via USB. When I send a document it shows error on the printer queue. Setup assistant says no device connected - but it is connected. I have the same problem with my new Macbook.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Feb 03, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
233
Points
HP PSC 1610 All-In-One InkJet Printer Printer HP PSC 1610 always printed till I... Answer I think I have a similar problem:HP PSC 1610 always printed till I installed Mac OS X 10.6. also does not digitalize since I downloaded: HP_Installer_PSC1600_v9.7 An error apears about a missing extention ? ? ? ? Carlos Moniz
My canon mg5220 printer is not printing anything. It just says error when the pop screen pops up. It doesn't give me an error code.
Hi Savannah,
Try deleting the printer entry completely and add it from scratch.
Here's how:
  • Go to System Preferences
  • Print & Fax.
  • Select the printer you want to remove,
  • Click the - (minus) button at the bottom of the panel.
  • Reboot the system.
  • Run Software Update to check for the latest third-party printer software and updates.
  • Make sure the printer is powered on, has paper, and doesn't have any issues such as a paper jam or low ink.
  • Adding, managing, or removing print queues may require an administrator account name and password--make sure you know one for your Mac.
How to add a printer
To add a USB printer
Mac OS X v10.6 comes with software for many third-party printers, so simply connect a USB printer and the print queue will be automatically created. If you do not see your printer in the "Printer:" pop-up menu after connecting it, go to the "To add a printer via the Print & Fax preference pane" section below.
To add "Nearby Printers"
With Mac OS X v10.6 you can quickly add a "Nearby Printer"--a nearby printer is a printer connected to the USB port on a Time Capsule or AirPort base station, a network capable printer that supports Bonjour, or a printer being shared by another Mac. Snow Leopard uses Bonjour technology to find nearby printers.
To add a Nearby Printer, all you have to do is select the Nearby printer you want from the "Printer:" pop-up menu:
Snow Leopard will automatically create the Print Queue.
To add a printer via the Print & Fax preferences pane
Control-click the System Preferences icon in your Dock and choose "Print & Fax" from the Dock menu. If the Print & Fax lock icon appears locked, click the lock icon and enter an administrator name and password when prompted. Click the + (plus) icon below the Printers pane on the left to open the Add Printer application.
From the Add Printer toolbar you have these default tools:
  1. Default - Used to get a list of all printers that your Mac can see via USB, Bonjour, and so forth. Tip: If you have a long list of printers, use the search field to find the printer you are looking for. Just click the printer in the list that you would like to add and Snow Leopard will add the printer driver for you.
    • Mac OS X v10.6 comes with software for many third-party printers. If an additional or updated printer software is available, Software Update will offer it to you. If you do not see your printer listed in the "Print Using:" pop-up menu or a Generic printer driver is selected, then the printing software may not be available from Apple. For more information about supported printers see this article. You can also visit the printer vendor's website for printer software, or contact them for technical support.
    • Once the driver is set, click the "Add" button to create your Print Queue.
  2. Fax - Used to add a queue for the Fax device connected to your Mac.
  3. IP - Used to add your printer network printers that don't use Bonjour or are on a different network subnet from your computer. Printers that support the Internet Printing Protocol (IPP), Line Printer Daemon (LPD), and HP Jetdirect (Socket) can be added in this manner. See your printer's manual or support documentation for information about how to setup the printer to use an IP-based printing protocol.
  4. Windows- Used to add your printer being shared via the Windows printer sharing protocol (CIFS). Tip: See Mac 101: File Sharing for details about how to add your Mac to a Windows Workgroup. This is often needed to see Windows printer shares.
Note: Any applications that are open before you add a printer will need to be quit and re-opened, in order to see all the features of the new printer.
Have Mac OSX Snow Leopard v 10.5.8 need to upgrade to 10.6
You'll need to purchase the software via Apple Store App. You should be able to do a inplace update or you can do a fresh install as well.
My apple OSX 10.5.8 Always says my computer is not on line. How do I get it on line
Is you computer connected to your route via an ethernet cable? If it is, check the port on the router to see if the connection light is glowing. Next, check you network settings and set the "Configure IP Address" to be "Using DHCP". This will also the router to allocate an IP address and settings to computer. Now see if you can access the internet.
Snow Leopard Support
Mac Basics Connecting your Mac to the Internet
My printer is turning on, but not printing, its telling me that the printer is offline and that there is a media jam. I have an I Mac please help.
Here's a quick summary of what's new for printing in Snow Leopard (read below for more details):
  • Apple's Software Update will automatically provide you with third-party printer software and updates.
  • "Nearby Printers" is a list of available printers that will appear right inside your printer dialog box. Adding a nearby printer is just a selection away.
  • You can simply connect a USB printer and the print queue will be automatically created.
  • You can create a PDF document from any application and have an automated workflow process it.
Before you connect your printer
  • If you are upgrading from Mac OS X v10.5, see "Upgrading Print Queues..." in the additional information section below.
With Mac OS X v10.6 you can quickly add a "Nearby Printer"--a nearby printer is a printer connected to the USB port on an Apple Time Capsule or AirPort base station, a network capable printer that supports Bonjour, or a printer being shared by another Mac. Snow Leopard uses Bonjour technology to find nearby printers.
nearby%20printer.jpg Snow Leopard will automatically create the Print Queue.
Note: Mac OS X v10.6 comes with software for many third-party printers. If an additional or updated printer software is available, Software Update will offer it to you. For more information about supported printers see this article. You can also visit the printer vendor's website for printer software, or contact them for technical support.
blank print _ fax system preference.png From the Add Printer toolbar you have these default tools:
2answers
Olympus P-440 doesn't work with Snow Leopard. What
The first thing that you need to do is to verify if your Olympus P-440 is if it's supported by Mac OSX 10.6.x (Snow Leopard). If yes, make sure that you've installed the correct driver for Snow Leopard.
You may check the link below:
http://driverscollection.com/?file_cid=41942227668e7c7e22782bc2081
This link contains a driver for Mac OSX. I assume that this driver will work with all OSX (starting from Tiger to Snow Leopard). If this driver will not help, you may need to contact the manufacturer, and verify the system requirements of your printer.
Thank you and good luck!
Lexmark X2650 scanner in Mac OSX 10.6.2 (Snow Leopard)
You need to update your driver by getting the latest software in the Lexmark website here. During software update what usually gets updated are the basic functionalities. In this case it looks like the scanner is not being updated as well. Hope this helps.
5helpful
2answers
Need OSX Snow Leopard Driver for Laserjet 1018. Have MacBook Pro 13".
This is the best solution for that problem and works perfectly...
http://blog.ragnarson.com/2010/01/mac-and-hp-laserjet-1018.html
Installed mac osx 10.6.1 and my fuji wont print HELP!
Some manufacturers have not caught up and updated their drivers for snow leopard yet.  You gots ta be patient and wait a couple months or call the manufacturer and ask for a comparable driver that will run off snow leopard. Go back to the previous OS if that was working your printer.  Don't fix it if it ain't broke.
2answers
Need driver upgrade for canon printer
thats tuff did cannon.com have it or mac website of not not made for u i know im sorry
k24674
Grand Canyon Tech
Grand Canyon Tech
