Pride Jazzy 1103 Ultra Standard Power Chair  Logo
Posted on Feb 02, 2010
Have to wiggle back wires to make it work - Pride Jazzy 1103 Ultra Standard Power Chair
life48dancer
Level 1:
Mentor:
An expert who has written 3 tips or uploaded 2 video tips.
New Friend:
  • Contributor 11 Answers
  • Posted on Feb 08, 2010
life48dancer
Contributor
Level 1:
Mentor:
New Friend:
Answers
11
Questions
Helped
3269
Points
26
You need to secure those wires. Do you have the ability to open where the wires enter? Make sure all electricity is turned off! If there is a warning, don't go there. Wiggle means loose connection that will fail soon. If you can open the area and make the connection firm (buy turning screws or re-wrapping the wire on the contact).
MR Oreck keeps cutting out
Cable has broken internally, wiggling is temporarily making contact which is why it then works. Get it rewired by a cometent person !
Oct 18, 2014 • Vacuums
MY ORECK KEEPS CUTTINH OUT IF I WIGGLE THE WIRE IT STARTS AGAIN IT IS AN ORECK XL UPRIGHT
Cable has broken internally, wiggling is temporarily making contact which is why it then works. Get it rewired by a cometent person !!!
Im getting no fire to the ignition control module
from the module, replace the wire back close to the harness. Wiggling shouldn't effect it anymore.
When attempting to start cranks fine but if i wiggle the wiring coming out the top of the fuel tank it would fire right up. Paid $600 to have this fixed several years ago. Would act up occasionally but...
The first thing would be to have the connector and the wiring checked, the wiggling would mean that there was a bad connection, this connection would cause higher than normal amp draw and this make the wiring heat up along with the pump, you may have destroyed the pump but then again the wiring may be so bad now that the wirng no longer makes a contact. thats my first thing to check.
2answers
I replaced the low beam headlight on the passenger side of my 1997 Blazer, but it still won't work, the high beam works fine.
check for a bad ground or check plug and back track wires with test light till you get power and fix the wire. Make sure you check for a good ground first. If all fails then run a new wire from the other low beam light to the non working one.
Loose wire in wiring harness
You could eliminate the harness plug all together by cutting each respective wire on ether side of the plug and hard wire it or crimp on blade or bullet style male and female solderless connectors, one wire at a time.
Aduz
Headlights work but parking lights dont..
if u have change and check the bulbs and fuses. great. fuses do go lose in a cherokee . move each fuse by hand while the lights are on or the switch is in the on position. if you find the problem this way. just take the fuse out and slightly twist the prong of the fuse and replace it back and ditto. make your daughter say " u d grate dad"
My 95 Gr. cherokee power windows wont work, its not the fuse
Did you visualy check the wire harness by the drivers door?
Peel back the boot and check for BROKEN wires.
Top Pride Health & Beauty Experts
Rob Hill
Rob Hill
Mike Cairns
Mike Cairns
Grand Canyon Tech
Grand Canyon Tech
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
