Question about Panasonic DVD-S25
Disc spins, then " Type of disc can not be played" message
Disc is put in, it spins excessively and noisily, then a message "Type of disc can not be played" appears. Thank you.
  • 484 Answers
It means the format of the type of cd u put in cannot be played by the system.
try playing the disc it on another player, if it does the same, it means the disc cannot be played. some players dont play mp3 format, blu ray, and some others, so you can check the kind of disc you want to play on it.
goodluck
Posted on Feb 03, 2010
6ya staff
SOURCE:
My CD player keeps displaying no disk and wont play the cleaner disc, is something dirty or broken?
Hello
If it does not play the cleaner disc, just inspect whether the disc inserted in spins inside it. You can check this by open the upper cover of the player, and inserting a disc into it. If inserted disc spins inside, and the player won't read it, the fault is with its laser pickup unit, and it should be replaced with same type and number.
If the disc dos not spins, the fault is with the sled motor [the motor that spins the inserted disc], has damaged, and should be replaced. OK.
Dec 25, 2011 | Sharp Audio Players & Recorders
Wat should i do when is displays no disc
Hello
If your DVD player shows no disc, even a disc is inserted, try to clean its laser head assembly, by inserting a cleaning disc in it and play atleast three times. Take it ejected each time before you play it. If it does not helps, open the top cover of your DVD player, insert a disc, and notice if the disc spins or not. If disc spins, and not reads, the laser picup unit of your DVD player is faulty, and should be replaced with same type and number. If its stripe wire connected between pickup unit and main board is detachable, try repalcing the strip wire first. In some occations, bad strip wire will show this type of problem.
If disc does not spins, the sled motor [the motor that used to spin the disc at high speed], is damaged and shoud replace it. OK.
Apr 07, 2011 | GE DGE100N DVD Player
The xbox is on with the green light and everything seems to be working, until you put a disk into the tray and it says reading then open tray, it makes no noise as though it is not spinning
Inspect and clean your disc Take a close look at the bottom side of your game, movie, or music disc (the side without a label or image). Are there scratches? Excessive scratches or smudges can prevent your console from reading the disc. Clean your disc Hold the disc by the edges without touching the top or bottom surfaces. Using a soft, clean, slightly damp cloth, lightly wipe from the center of the disc outward.
· Note Use ONLY water to clean the disc.
· Once the disc is clean, load the disc into your console and see if the disc plays.
Click here to download repair guide...if u need
Dec 28, 2010 | Microsoft Xbox 360 Console
I was playing a game yesterday and stopped for about 2 hours. I then turned my xbox on and put in a movie, started to get the "open tray" message. I tried several other CD's and games but it...
  • Note Use ONLY water to clean the disc.
  • Once the disc is clean, load the disc into your console and see if the disc plays.
  • Dec 22, 2010 | Microsoft Xbox 360 Console
    I have put in a dvd into the slot, it will not play, the message saying self check keeps displaying
    Hi
    Assuming that the machine accepts the disc in and begins to spin the disc, you will hear a spinning sound, and goes no further than this point, it would suggest the optical pick up is unable to read any data on the disc or the spindle motor is unable to spin the disc to its correct velocity, it is more than likely the laser has failed, either way the machine needs to be serviced.
    Regards
    TechSupp12
    Dec 12, 2010 | Panasonic Televison & Video
    Getting "can not play disc" message from sony DVP-NS725P dvd player.
    Have you tried taking off the cover to see if the disc is spinning inside when you get this message? The motor that spins the disc could be shot.
    Sep 04, 2010 | Sony DVP-NS725P DVD Player
    When playing a DVD, we experience frequent stops and starts..
    It may be a dirty lens, or perhaps the drive is getting stuck.
    The first thing to try, if you feel up to it, is to clean the lens. First, you'll need rubbing alcohol (peroxide isn't the same thing) and a Q-tip. Add a tiny amount of alcohol to the Q-tip and gently rub it against the lens of the laser. After a few times around the lens, use the dry end of the Q-tip to pick up any excess alcohol lying around. Put the player back together and try playing a disc.
    If it still doesn't fix the issue, then the following steps can be taken.
    Have a disc in the drive and while it's off, open it up. Start the drive and see if it's spinning freely. If not, then onto the next part.
    Use some WD40 on the shaft of the drive motor that makes the disc spin. Just use a little bit at a time and work it in by manually spinning the spindle (what the disc rests on). Once that's finished, put the disc back in and reassemble the drive, plug it in, turn it on, and see if it spins better.
    Jun 05, 2010 | Zenith DVD2381 DVD Player
    Won't play a disc.
    I just cleaned the lens at it plays great now.
    Jan 26, 2009 | Sony CFD-Z501 Boombox
    Panasonic DMR-ES15
    Just unplug it and let it sit for half an hour. Then try playing the lens cleaner disc, the problem would be fixed....
    Sep 10, 2007 | Panasonic DMR-ES10 DVD Recorder
    DVD pLayer Not spinning DVD's
    if your dvd player is 5 years old or more i suggest you trash it and get a new one but if its not try to clean the lens manually with a peace of bond paper. rub the paper gently on the surface of the lens
    Jul 13, 2007 | Sanyo DWM-3500 System
    Panasonic DVD-S25 Logo
    827 people viewed this question
    Top Panasonic Televison & Video Experts
     Grubhead
    Grubhead
    Demonic-2011
    Demonic-2011
    Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
