My freezer sit on our patio and when the temps dropped to 20 degrees two weeks ago it stopped working. We unplugged it for a few days then replugged it in and it still does not cool. Any ideas?
Re: My freeer stopped working after the temps dropped
Freezers have a range of ambient temperature uses
most are plus 10c to 35c if using some units in garages etc. they just dont work...too cold for the poor things...
This is normal. All commercfial freezers must defrost 3 to 5 times a day, or they will freeze over at the coil and then stop freezing. A timer in your freezer turns off the compressor and turns a heating element on for 10 to 15 minutes. During that time the coil heats and melts frost from the coil. Usually within 30 minutes the temperature will briefly rise to 20 t0 25 degrees F and then quickly drop down to 0 degrees F. The food rarely defrosts in this short period of time..
Hi, As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips. If your refrigerator is running but warm, then… Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
If this is a self defrosting freeze,then it is normal to periodically see an elevated reading during a defrost cycle. At 20 degrees, it was probably ready to complete its defrost cycle and come back on to return it to your cold setting.
Move the refrigerator to a room that is at least 50 degrees F.
Temps on most refrigerators are regulated by the fresh foods temp. If your garage is let's say 35 degrees, the fresh foods temp will most likely never raise enough to turn the refrigerator on. With the refrigerator never running, the freezer compartment will warm to 35 degrees, resulting in everything melting. Even if garage is a bit warmer, say 45, the refrig will not run long enough for the freezer to maintain a low enough temperture. If the garage temp falls to below freezing, say 20 degrees, the food in the fresh foods compartment will freeze. (outdoor beverage dispensers have internal heaters to prevent product from freezing !) Please don't rate this if not a Fix-Ya for you, as anything else lowers my score.
Since this is a new freezer it should be serviced by the people who sold it to you in order to avoid any warranty conflict. The fan blades of these units are of a slip fit onto the motor shaft. It is possible that the fan blade has come off the motor shaft.
ice cream is always the last to freeze and a temp of minus -10 degrees is usually required to get it to get hard. if you put the ice cream in the door it will be especially tough to freeze. a good thermometor is a good investment as you can observe the temps. usually ten degrees or 20 degrees is what they run. yes they do cycle on and off as long as they hold temps thats good. the outside of the freezer gets warm because the hot compressed refrigerant is spread through piping near its surface giving up its heat of compression . setting the stat to max will freeze the ice cream eventually but utility bill suffers . good luck
