Question about Goodmans GTVL19W17HDF 19 in. LCD TV
2 year old LG Flat screen TV keeps freezing
Sometimes if TV has frozen while out of the room and it has been for a period of time, the last picture where it has frozen is still visible on the screen. Eventually fades away. Sometimes when screen is frozen it will give a very loud smashing sound, like you would expect if the screen was shattered.
    New Friend:
It is not your tv its channal 9, switch off totally at the wall, disconnect aerial, turn on - tune into channel other than 9, plug in antenna again
Posted on Feb 04, 2010
  • nadro Jan 16, 2013
    what!!?
6ya staff
SOURCE:
Volume picture & level its on frozen on screen for days goes away then comes back again & TV or HDMI on top right screen will freeze on screen to. menu button works sometimes.
First of all try to update the firmware. If its didn't help then you can go for a new mother board .
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Mar 05, 2016 | LG Televison & Video
My lg tv has sound but no picture appearing,what seems to be the/ problem
When the picture goes out again, dim the lights in the room. Take a bright flashlight and shine to on the screen, do you see a faint picture?
Feb 02, 2013 | LG 32LG30 32 in. LCD HDTV
For the second time since I have my Borderless Flat screen LED TV the image get frozen and I get the LG Logo stating Not Programmed. It came back to normal last time after a while but I do not remember...
Contact LG tech support. If this has happened before, you maybe looking at an issue with the internal storage (memory) of the tv, which may require service (even though only 2 months old).
Aug 21, 2011 | LG Televison & Video
I have a Westinghouse SK-32H240S 32" flat screen
First when tapping changes the picture you have somewhere a bad connection; in electrical board or wiring.
When the screen goes blank after a while means some capacitor is bad/old.
Mar 13, 2011 | Westinghouse SK-32H240S Television
Picture distorted with images and outlines
Unfortunately this is an unrepairable problem called screen burn.
This happens commonly with old displays and can only be fixed by replacement.
More information can be found here: http://en.wikipedia.org/wiki/Screen_burn-in
Mar 27, 2010 | LG Televison & Video
3 year old 42in LG LCD TV scrren went blank
You will either have a fault with the inverter board which drives the backlights or a faulty backlight in the screen. If the problem is a backlight then a replacement screen is the only cure. One or the other is breaking down after it has been opn for a certain period of time, have an engineer call out & check with a tester if it is a screen problem.
Dec 19, 2009 | LG 42LC2D 42 in. LCD HDTV
Frame periodically freezes on Vizio 37'' TV
Your statement is confusing. Why? because you stated " This tv is hooked up to an Antenna with a Booster", then you said it's connected to Cable Tv. I will answer this both ways for you.
If your on an Outside Antenna or Rabbit Ears, even with a booster, if the signal is not good prior to getting to the antenna then a booster only amplifies what it see's and that may be as we call it, "garbage". In a HDTV the freezing can happen when that situation is at hand, however if you are on Cable and we know the signal is clean ( we hope? ) then the problem is with the software in the set and should be looked at by a service center, or if it's right out of the box then I would exchange it.
In digital technology there's no maybe, it's yes or no! If the signal is not what's required, then you get what your experiencing now, IF, there's nothing wrong with the set, and there may be. I just repaired another brand doing the same thing and it was the Main Control Module. So, I hope I helped you in isolating the problem. Please keep me posted...
Feb 26, 2009 | Vizio SV420XV 42 in. LCD TV
HELLO to the guy saying hello ... I am on cable and have the same freezing problem ... so take the attitude and shove it!!!!!
Dec 17, 2008 | Vizio L37 Television
LG TV not turning on
Yes you can get this fixed and it is still worth it. It may cost $200 but it should last a long time.
Nov 12, 2008 | LG 42LC2D 42 in. LCD HDTV
Goodmans GTVL19W17HDF 19 in. LCD TV Logo
1,345 people viewed this question
Top Goodmans Televison & Video Experts
Ekse
Colin Stickland
Colin Stickland
martin hogg
Are you a Goodmans Televison and Video Expert? Answer questions, earn points and help others
