My acer orbi cam 3690 windows xp was working but now it is not. It does not show in the camera and scanner box in the control panel. It does not light up. But it did work on skype just previously to that and I tried to enlarge the photo and it doesn't work now. It doesn't show on msn either. PLEASE HELP
SOURCE: Acer orbi cam
Start - Programs - look for Acer Empowering technology Acer E-recovery - choose Restore - choose Apps and Drivers at the bottom of Restore tab (it will say extracting) - once extracted - click Install - click Vista on the left - click Drivers - click Camera or CCD - on the right side of the screen, click a phrase that has something like "Install now", follow on screen instructions.
** Note ** When the My Pictures or Pictures folder gets full, camera will not work - Cut and Paste all pictures in that folder to another folder and restart Orbicam program.
There is a utility bar that you can install that lets you change the default application folder:
If that does not work then do this:
Start - Programs - look for Acer Empowering Technology then Acer E-Recovery - The look at the bottom and you will
"Backup", "Burn disk" and Restore" choose Restore - choose Apps and Drivers at the bottom of Restore tab (it will say
extracting) - once extracted - click Install - click Vista or (XP) on the left - click Drivers - click Camera or CCD - on the
right side of the screen, then look for Bison driver or (or your model which can be found in device manager - control panel - system - device manager - Imaging devices) you have then click a phrase that has something like "Install now", follow on screen instructions. Then repeat steps above and instead of driver choose Bison (or your model which can be found in device manager - control panel - system - device manager - Imaging devices) Utility
SOURCE: acer orbi cam not working
I think ur laptop webcam driver not installed properly.If ur laptop have windows vista operating system then do these steps.
Goto Start - Programs - Recovery Manager - Recovery Manager.In that recovery manager,click on next.Its shows the Software reinstallation page.Click on next button two times.Its shows the software lists.Select the webcam software and click on next button.After reinstallation completed , u restart laptop and check it.
If ur laptop have windows XP operating system then u uninstall the webcam software through Add/Remove program and restart it.After restarting ,Reinstall the web cam software and check it. If u doesnt have webcam drivers then u go for nearest service centre and install it.
Thanks
Ive found an interesting discussion about the orbicam at a website called the Acer Guy.
I am going to assume you are on Windows Vists unless I am otherwise mistaken. Click here to read what the site has to say and for possible suggestions on where to find the drivers for it.
http://www.theacerguy.com/2007/04/14/orbicam-driver-for-windows-vista/
