Dbutler1221, Possible Bad "switch-mode-power-supply"/"CCFL inverter circuit" that is or has developed an intermittant solder connection OR has problem with bad capacitors on same SMPS circuit board. You or a qualified electronics technician will need to open unit and visually inspect and test unit if WARRANTY SERVICE not an option. If DIY repair interests you, read some of the older (higher page num) responses to BLACK and or BLACKandBLANK LCD screen owners I have already done. Please come back to this posting you have done and rate my response after you have done the research and feel I have pointed you in the right direction. 12fixlouie Bye for now
